1960 to 62 lower ball joints
this may sound stupid but can anyone tell me if you just cut the old lower ball joints out on a torsion bar suspension. it looks like the only option but I just want to make sure I'm not missing something?
Senior Enthusiast
Re: 1960 to 62 lower ball joints
Perhaps these pages from the 1960 Chevy Truck Shop Manual will be of help:
![]() ![]() ![]() The ball joints are referred to as spherical joints in the manual. Good luck.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
appreciate it but that's not the lower ball joint, its riveted in from the top but does look similar at the frame. also from 60 to 62 its a torsion bar front end. thanks again
Senior Enthusiast
The pages above are from the 1960 shop manual and show the torsion bar suspension parts. Page 3-14 (the center page) shows the 60-62 ball joint replacement steps beginning at the paragraph titled "Repairs" near the bottom left. Picture 21 in the upper right shows the attachment design of the ball joints. Here's another drawing from page 3-8 showing the details of the attachment point:
![]() If yours are different someone may have modified the control arms during the trucks lifetime.
That's excactly the same as on my '60 truck! Was an easy fix!!
You will have to cut the top heads of the factory rivets and air hammer or punch them out with a hammer (a very strenuous job)! New ball joints will have replacement bolts and nuts.. Good luck!
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
#7 | |
Who Me?
Just cuz you cut the head off the rivets doesn't mean they will slide out. Below the surface, they are flared out from being pressed in, and they are still a mother to get out.. We ended up drilling out most of the rivet and punched out the rest.. That was the trick that helped me get them out. Start at post #34 and go from there. http://67-72chevytrucks.com/vboard/s...=508507&page=2
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Still 39.99 at CPP
Cut the rivets out then bolt in the new ones on.
