Old 04-15-2015, 08:13 AM   #26
snipescastle2
snipescastle2's Avatar
Talking Re: Serious Black
Nothing much going on right now with my project as I'm working 10 Hour days, at least for another week. I did score a real nice bed cover for my ride, it has an aluminum frame with the supports under the canvas cover, and that clamps to the bed rails, the snaps are attached to the frame only, no drilling.
I'll have to get some pics later on, and the best part- only paid $50.00 for the whole thing!!! Yeah!
I fabricated a Vacuum reservoir out of 2 - 4" schedule 40 PVC pipe caps and a small piece of pvc pipe, cemented them together. I sanded them smooth, and painted them bright aluminum. I drilled and tapped the upper end for tube fittings and installed a drain valve ( I doubt it was necessary) but I installed one anyway. Now, I just need to find a small vacuum gauge for the top. I am bending up lots of stainless tubing for fuel and for the brake booster vacuum lines ( the solid lifter cam I'm going to run isn't very well suited for vacuum assisted brakes) I suppose I could always do the hydroboost setup, but for now, the reservoir will fill the bill.....
Have a good one!
Ben
snipescastle2 is offline   Reply With Quote
Old 06-03-2015, 08:12 AM   #27
snipescastle2
Re: Serious Black
Okay Folks, been a while since I posted updates....here's a few teaser shots I got yesterday from the painter...sorry, these are cell phone pics, but they beat none at all!!!
Have a good one!
Ben
Old 06-04-2015, 02:07 PM   #28
snipescastle2
Been working on my power windows mod wiring, got that down to a science now. I'll post a small video later of the power window motor running both forwards and backwards. here is a picture I made a crude drawing of how I wired the micro switches to make the window go both up and down....enjoy!
Ben
Old 06-04-2015, 11:19 PM   #29
swamp rat
swamp rat's Avatar
Re: Serious Black
Pretty slick!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-24-2015, 09:00 AM   #30
snipescastle2
Well,
Just got back from Cancun,Mexico Saturday, now it's time to focus on my project once again! I'm Bummed out my painter hasn't finished my Cab and bedsides He had some issues with a customer's paint job he did, color wasn't spot on....had to refinish a panel or two....anyway, he says I should have it by this weekend (crossing my fingers)
Couple of more things I plan to do with my interior I'm planning to do- I am going to use a Black "Mother of Pearl" drum wrap material to cover my dash cluster (like the original woodgrain decal) and the glove box as well. not cheap, but should look pretty awesome!!! I already did the "Camaro Tach Mod" replaced the original bezel with a new one, should be impressive!
Have a good one!
Ben
Old 06-24-2015, 11:12 AM   #31
88Stanger
88Stanger's Avatar
Re: Serious Black
Awesome job so far.
88Stanger is offline   Reply With Quote
Old 06-24-2015, 11:41 AM   #32
Stickman
Stickman's Avatar
Re: Serious Black
Very nice, being a drum collector myself I like the wrap idea. It's looking good.
Stickman is offline   Reply With Quote
Old 06-24-2015, 01:53 PM   #33
snipescastle2
Yeah, I liked the mother of pearl look, guess after watching my brother's band playing all the time, (my little Brother is a drummer) the look kinda grew on me......
Ben
Old 06-24-2015, 08:30 PM   #34
snipescastle2
Here's a video of the power window switch I made out of a broken door handle relay and a couple of micro switches, sure beats paying $180 for one switch!!!
Enjoy!
Ben
https://youtu.be/Qp52AFpZfXQ
p.s. I didn't show the actual regulator in the clip, but the wiring and action of the motor shows how it works, if you look at my pictures a few posts back, you will understand how it works.
Old 07-15-2015, 02:23 PM   #35
snipescastle2
Re: Serious Black
well, I decided to fix the grill surround I had. it had a pretty good dent in the right front corner, above the headlight. after "dolly-ing" the dents out, and sanding/polishing,and working the area flat and smooth as I could get it, I was going to remove the anodize coating and attempt to polish it all together, but decided to try a diffrent approach.....I had some "Chrome" Powder coat powder left over from early on, I figured why not.
I think it turned out rather well, considering I'm not a "Body Man" by any means....any way's, here's a few pics.... I'll post some of the completed and assembled grill tomorrow.
Enjoy!
Ben
Old 07-16-2015, 01:21 PM   #36
Low Elco
Re: Serious Black
Looks good! Glad to see you're still movin'!
Low Elco is offline   Reply With Quote
Old 07-16-2015, 01:38 PM   #37
snipescastle2
yeah, I'd be moving much faster if I could get out of "Paint Jail"
Have a good one!
Ben
Old 07-28-2015, 08:28 AM   #38
snipescastle2
getting closer and closer. my painter had a slight set back with his equipment, his dehydrator/oil water separator failed, and had to get a new unit installed, but he's back on track now. everything final primed and ready for the final blocking, seam sealer then base coat. here are a few pictures:
Have a good one!
Ben
Old 07-28-2015, 10:01 AM   #39
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: Serious Black
lucky!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 07-28-2015, 10:21 AM   #40
snipescastle2
Well, guess I'm kinda lucky, but don't get me wrong, it's been in "Paint Jail" since May.........the guy had "Bitten off" way more than he could chew, (too many jobs at once) along with a few set backs on some of the projects he did, but, he's on board with it now, I'd sure like to see the color and clear done by this weekend, but I'm not going to hold my breath, with the heat and humidity we have been experiencing here in Missouri, I'd rather be on the cautious side and have it right....but at least I'm moving in the right direction!!!
Have a good one!
Ben
Old 07-28-2015, 10:46 AM   #41
Justin@EntropyRad
Re: Serious Black
Lucky from the off-road excursion not damaging anything. The paint Jail is becoming a necessary evil it seems
Justin Novick
(773) 303-8251
Sales/Support
Old 07-28-2015, 10:48 AM   #42
cooperhw
cooperhw's Avatar
Re: Serious Black
Truck project looks like it is coming along nicely. I hear you on the heat. Been painting mine for the last 5 weekends (couple pieces at a time) here in Phoenix AZ. 86* at 6:00AM and 106* average high. Bout got all my stuff in color now. Hopefully start color sanding and buffing this weekend so I can begin hanging sheet metal. The end is in sight even if it's still a ways down the road. Hang in there.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-30-2015, 03:26 PM   #43
snipescastle2
Here's a few pictures of my Grill after assembling it, not exactly chrome, but very nice otherwise!
Enjoy!
Ben
Old 08-05-2015, 02:54 PM   #44
snipescastle2
We have Paint!!! Yahooooooo!!!! here are some pics of the progress as it happened, the painter finished spraying the cab this morning, and is cutting and buffing the rest of the panels he did the other day! Man, am I happy!!! Now, to get it all home without incident........... some of these pics show the base coat and a couple have the clear, I'll post some more later!
Enjoy!!!
Ben
Old 08-05-2015, 02:58 PM   #45
snipescastle2
more pics
Old 08-05-2015, 03:34 PM   #46
Justin@EntropyRad
Re: Serious Black
slick!
Justin Novick
(773) 303-8251
Sales/Support
Old 08-11-2015, 03:35 PM   #47
snipescastle2
well, finally got the cab mounted and brought some of the panels home. the painter is still wet sanding and buffing the hood, doors and left bedside. but, I am thrilled to finally have the cab on so I can get busy putting the beast back together!!!! here are some pics from the other day.....
Have a good one!
Ben
Old 08-11-2015, 03:37 PM   #48
snipescastle2
pics
Old 08-11-2015, 04:11 PM   #49
summitflier
summitflier's Avatar
Re: Serious Black
Paint is looking good. Never really been a fan of black, but I have to admit.. yours looks pretty sharp.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 08-11-2015, 07:07 PM   #50
snipescastle2
Re: Serious Black
Thanks! If it wasn't for a friend in high school that showed me one back in 1981, been hooked on having a black one ever since. Had lots of people tell me I should do a different color, but its mine.... have a good one!
Ben
