Old 04-15-2015, 12:10 AM   #26
Root2812
Root2812's Avatar
Re: Glamorous Gena
What pinion angle are you using?
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 04-15-2015, 12:26 AM   #27
Hawkerdriver
Hawkerdriver's Avatar
Re: Glamorous Gena
After talking with the drive line shop I have a half a degree down at the tail shaft they have suggested 0 to 1 degree up on the piñon. For the length of the driveline. I have great clearance at 0. 1 degree it's pretty tight. I Have a ford explorer rear also.
Hawkerdriver is offline   Reply With Quote
Old 04-16-2015, 10:39 PM   #28
Hawkerdriver
Re: Glamorous Gena
I am hesitant to post this for fear of the heckles of my welding LOL. Kept the original transmission crossmember and fabbed up a new one for the 4l60e. Won't look bad after some paint. no one should be under this thing looking anyway.
Old 04-16-2015, 10:51 PM   #29
Advanced Design
Advanced Design's Avatar
Re: Glamorous Gena
More progress! Making instead of buying things is part of the fun.
Advanced Design is offline   Reply With Quote
Old 04-16-2015, 10:56 PM   #30
gregg pellicer
Re: Glamorous Gena
Is that mount a solid mount? It look's like it. If so not a good idea
gregg pellicer is offline   Reply With Quote
Old 04-16-2015, 11:00 PM   #31
Hawkerdriver
Re: Glamorous Gena
Yes as the old one was too? Thought and suggestions I'm thick skinned
Old 04-16-2015, 11:07 PM   #32
Sim6
Sim6's Avatar
Re: Glamorous Gena
Don't worry about your welds and what others may think. There is always someone worse at it than you
Sim6 is offline   Reply With Quote
Old 04-16-2015, 11:10 PM   #33
gregg pellicer
Re: Glamorous Gena
You need a regular rubber trans mount. Frame flex could crack transmission, Vibration will be transmitted, Same reason's you don't mount the engine solid. There is a reason that no modern car's or truck's mount driveline solidly.I'd cut that mount off and redo it for a standard trans mount. Just my opinion but this is what I do for a living.{ Trans tech at chevy dealer } I'm sure other's will chime in. I am not trying to be critical only trying to help
Gregg
Old 04-16-2015, 11:15 PM   #34
Hawkerdriver
Re: Glamorous Gena
Gregg, Thanks yes I think I can keep some of this and add the mount possibly to it another way. Thats why I post you eagle eye guys will keep me straight. Stby for round two..
Old 04-16-2015, 11:38 PM   #35
Hawkerdriver
Re: Glamorous Gena
just ordered a new mount i will be reverse engineering it to work with that original crossmember I have. So simple not really sure why I hadn't thought about that. cheaper to fix it now for sure....
Old 04-17-2015, 10:03 AM   #36
iowaboynca
iowaboynca's Avatar
Re: Glamorous Gena
https://www.youtube.com/watch?v=Idk3BVDVHq4
when you set up your pinion angle, make sure the the output of your transmission and pinion are paralell or in phase. i attached a video that helps explain it all
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 04-17-2015, 10:41 PM   #37
Hawkerdriver
Re: Glamorous Gena
Gregg, here is the new one i will use a larger plate now that I've got the trial fit done..
Old 04-18-2015, 07:07 PM   #38
gregg pellicer
Re: Glamorous Gena
That's more like it just make sure you still have correct pinion angle
Gregg
Old 05-04-2015, 10:34 PM   #39
Hawkerdriver
Re: Glamorous Gena
Well Most parts have showed up, still a few things on back order. Wiring Harness is finished and lengthened, fuel rails came with the new EV1's I built some spacers to make it work, Frame is in Powder Coat now. most front end suspension parts are being painted. I have fabed up some seat brackets for the new seat. All the holes I wanted welded up in the Firewall have been done still doing some sanding and grinding of my welds.. Painted up the intake. Next week should have some pics of her in reassembly mode.
Old 05-31-2015, 10:41 AM   #40
Hawkerdriver
Re: Glamorous Gena
It's been almost a month but I finally have some progress that I wanted to share. Last of the front end parts came in Friday and here is what I have been up to. IFS has been installed, rear end has been blasted, new brakes, rotors, calipers, paint and welded for the the 4 link. 4 Link installed, two of the rims have been powdered also to make sure I like the color. frame has been blasted and powdered. Here are some pics of my progress. I thought this project was just dragging but my wife reminded me that a lot has been accomplished in 90 days. Patience
Old 05-31-2015, 12:29 PM   #41
Advanced Design
Re: Glamorous Gena
Great progress! Looks really good.
Old 05-31-2015, 06:54 PM   #42
iowaboynca
iowaboynca's Avatar
Re: Glamorous Gena
Looking good!
Old 05-31-2015, 06:56 PM   #43
gregg pellicer
Re: Glamorous Gena
Lookin good
Old 05-31-2015, 08:22 PM   #44
Sim6
Sim6's Avatar
Re: Glamorous Gena
Good progress, drivetrain looks good.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Old 08-24-2015, 09:19 PM   #45
Hawkerdriver
Re: Glamorous Gena
Well quick update as I've fell asleep at the wheel in the picture department but.... I know some will not like this but I modified the dash for the new stereo cut and welded accordingly. I've completely stripped the cab, added altman latches, installed a new brake booster and pedal assembly. done some minor body work put the cab on the trailer and it has been delivered to the painter for firewall and interior paint so I can mount it to the frame and start with all the wiring. I do have brake lines installed from the back forward going to get the fronts done soon. I ordered a brand new bed and fenders online so all new metal to work with in the rear.. Elk archery season starts Saturday and nothing will be touched for a month now..
Old 08-24-2015, 09:22 PM   #46
Hawkerdriver
Re: Glamorous Gena
More Pics the kids pool noodle did good for a simulated steering column.
Old 08-24-2015, 09:37 PM   #47
iowaboynca
iowaboynca's Avatar
Re: Glamorous Gena
You've got some progress in...good job!
Old 10-13-2015, 12:14 AM   #48
Hawkerdriver
Re: Glamorous Gena
Well The cab the new bed metal, and front fenders, new grill, bumper, hood, etc. have been shipped out of town for body work and prep. The painter wants the chassis by the end of November to fit and start the process of paint and mock up of the body. My goal is to have this wired and fired by Thanksgiving. the new accessory drive showed up today. all brake lines have been run, fuel tank has been purchased with fuel pump and tank mount is off to powder coat. The radiator did not sit as I expected and I had to farm out the modification of the flange on the sides to recess into the support to gain more room. Its moving along.....
Old 10-13-2015, 08:53 AM   #49
Advanced Design
Re: Glamorous Gena
Looking really good. What fuel tank did you use?
Old 10-13-2015, 09:04 AM   #50
Hawkerdriver
I am using a fuel injected Tanks Inc tank. I only had it sitting on a floor jack in the picture.
