06-05-2015, 01:38 PM | #26 |
Re: Shawley's 1969 C10 Project
Got a bunch of work done, not much for pictures,
Alternator mounted up Transmission cooler mounted up Rad all installed Rad fan in there now too We fired it up the other day too, and it started just fine and ran. Getting very close to driving it!! Did Por15 gloss black paint on the floors with the rust protection. More wiring fun, looks like a mess but its just getting all cleaned up and integrated Then did my Wirez sound deadening on the floors and back wall! It's getting so close!!!!!!!!!!! |
06-06-2015, 11:43 AM | #27 |
A buddy from work came to help out and get the din hole for me new Pioneer deck cut out, I knew if I cut it, the hole would be crooked
We got the Dakota Digital cluster all working, just need to calibrate the speedo, once I get it driving My Lumens LED headlights are working, and so are my LED side markers and park lights! Means all my wiring was correct haha. |
06-06-2015, 01:08 PM | #28 |
motor exploder
Nice work - what brand are those parking lamps?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
06-06-2015, 01:11 PM | #29 |
Thanks! They are all from LMC, I don't remember what brand they were though
Posted via Mobile Device |
06-09-2015, 10:42 AM | #30 |
I got he under hood all wired up, 140amp alternator fused to the battery, my Accuair all connected to the battery, the stereo power routed to the cab, and a couple good grounds for the battery and in the engine bay.
My buddy Luke came by and worked on my truck with me till very late Saturday night so we got lots done, cleaned up all the wiring and got my deck installed, along with all the RCA's and speaker lines for the future stereo routed. Deck installed, heater controls reinstalled, ash tray back in, usb mounted, and then the sub level control where the old manual choke was. Got the cluster all in, tested and working 100%, and laid down the carpet in the cab. It ended up fitting damn good, just need to do a little adjusting because this carpet is for a truck with a bit more of a raised floor for a shifter as my truck used to have a floor shifter, but didn't have the raised floor. All powered up and working, just need my amps/speakers/custom kicks and I'll have sound Lots more to do but so little left to do! Really just need my shocks from Bag Barn, a coolant overflow, and mufflers and I'll be ale to take it around the block, then hopefully toss the box back on. |
06-09-2015, 11:20 AM | #31 |
really coming along!
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
06-11-2015, 10:53 PM | #32 |
Seats in,
Carpet too! And the steering wheel!!! And got a rad overflow tank |
06-18-2015, 03:52 PM | #33 |
Truck is soooooo close to being finished up!!!! New mirrors on it now too.
Transmission needs one thing adjusted/changed and then the bed will go on and it's ready to drive! Just needs proper exhaust and an alignment. Engine is pretty well all finished up, and we redid the alternator bracket as the last one was flexing way too much Interior is all finished up besides the stereo, need to still build custom kick panels and my sub box. False gas cap on there too. Built a bracket for the Accuair controller |
06-23-2015, 10:23 AM | #34 |
Well I got the truck going and driving!!!! My buddy Ryan came by and got the majority of the tranny issues resolved, as someone has modified it to run no lock up.
Took it around the block, everything is working awesome, the accuair, the motor, all of it! Can't wait to get the bed on and get it all going Need to also calibrate my GPS speedo |
06-23-2015, 12:53 PM | #35 |
That looks beautiful! Nice work!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
06-23-2015, 01:16 PM | #36 |
Rusty Nuts
Nice build, nice truck thanks for sharing.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
06-24-2015, 01:10 AM | #37 |
Nice work!
06-25-2015, 06:17 PM | #38 |
truck looks amazing. great work
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
06-30-2015, 07:57 PM | #39 |
Thanks guys!
Got box ready, and cut the hole for the fuel filler Then thanks everyone for lifting, when I couldn't and drove it to the garage! |
07-21-2015, 01:04 PM | #40 |
The truck is getting so close to completion, had some transmission issues that we thought could be a simple fix, but turned out that the transmission itself was toast.
Had 1st and 2nd gear but no 3rd or 4th so got it towed to a local transmission shop, the tow truck driver himself owns a 72 Suburban Once I got there the owner had a 66' C10 himself, and knew lots about these trucks and also lots about the 700R4 transmissions, so it was great to get it worked on there Turned out it needed to be fully rebuilt, so that's what I had them do, and now I'm able to drive it! Just needs some exhaust work, the bed cut out for the diff, the stereo completed and and then it's finished!!! Well at least for this season. Not bad for 8 months |
07-21-2015, 02:34 PM | #41 |
Great work. You should be proud.
07-22-2015, 12:01 AM | #42 |
Love this truck, nice to see another Albertan member on here!
Cole. 1967 GMC c15 1991 k2500 2005 2500hd Duramax |
08-31-2015, 01:13 PM | #43 |
Thanks guys!
Might as well at some more current pics, still haven't been able to do my stereo yet, just no time. At Drift For The Kids at Castrol Raceway Took it to Rock'n August Drive In Movie, wanted to recline the seats to just lifted the front and dumped the back! Rock'n August Car Show At the shop one day
My 69' C10 build thread |
08-31-2015, 02:40 PM | #44 |
That looks really good! I love those wheels.
08-31-2015, 03:26 PM | #45 |
very nice job!
09-02-2015, 04:30 PM | #46 |
What are the specs on your wheels?
09-03-2015, 08:28 AM | #47 |
Still Learning
Awesome work on this truck. You really took it a long way in a short period of time. Looks great too!
