06-12-2015, 08:50 PM | #1 |
tbi plus turbo....... any experiences?
Pretty much like the title says. Thinking bout boosting a 454 tbi motor, mainly wondering if that style of tbi can keep up with big boost, or if I should go with a aftermarket system.
06-13-2015, 01:41 AM | #2 |
meowMEOWmeowMEOW
Re: tbi plus turbo....... any experiences?
Its possible but your pretty limited by parts selection. You only have two injectors to work with, so they have to be putting out a significant amount of fuel. The tbi unit itself isn't really designed for pressure either.
Its a bit more common to switch to a blowthrough carb setup, or go with aftermarket efi.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
06-13-2015, 03:29 PM | #3 |
Registered Truck Offender
Wondering what kind of ECM you would use in place of the OBD-1,,,hmmmmmmm
That is assuming were talking about the pre 96 TBI motors,,, right?
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
06-13-2015, 04:07 PM | #4 |
I have seen a few BBC guys adopt an LS computer using a crank trigger.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
06-13-2015, 05:49 PM | #5 | |
meowMEOWmeowMEOW
I think a company called WynJammer used to do TBI superchargers, so they might be a resource. You can run pretty much anything off the LS style ECM's, it just involves using a ton of blank PID's.
06-13-2015, 11:07 PM | #6 |
60-66 Nut
I don't know about the OEM throttle body, but I do know that the older Holley Pro-jection throttle bodies will handle boost. You can change out the injectors in the Holley for larger injectors.
06-14-2015, 10:54 PM | #7 | |
At the body shop.
Nate says he can, small or big block
" That didnt make it any newer " " Dont antique the equipment " |
06-14-2015, 11:17 PM | #8 |
meowMEOWmeowMEOW
It functions in place of the internal reluctor wheel & sensor, but otherwise works pretty much the same.
06-15-2015, 12:26 AM | #9 |
06-15-2015, 02:32 AM | #10 |
meowMEOWmeowMEOW
How many of those are floating around?
06-15-2015, 09:37 AM | #11 |
