Old 06-18-2015, 01:02 PM   #751
Texas1963
Texas1963's Avatar
Re: Tricked-out Chevy six cylinder engines
Here's my 230 before pic's. Gonna order the Offy 2X1 Intake and another Carb today. I'm going to look into getting a stock exhaust manifold and having another flange welded on to run dual pipes. If not that route then I'll get the shorties from Cliffords. Right now I'm running 2" straight out to the bumper and it sounds awesome with a fishtail tip from a Harley I had hanging in the shop. I'm looking at scoring a 292 and going all out with it like I've seen here. Lot's of good info and expertise here as well. Thanks in advance as well for any tips or pointers.
Chief US Coast Guard Ret.
1963 SWB Fleetside Chevy L6 230
1962 Cadillac Coupe Deville 390
Texas1963 is offline   Reply With Quote
Old 06-20-2015, 09:59 AM   #752
TJ's Chevy
TJ's Chevy's Avatar
Awesome that your joining the 6 banger brother hood. lol That 230 can be made into a nice machine with some effort. But the 292's are not hard to find. My 292 will be making around 310 hp and 330 torque at least and it was just a "mild" street build. Still room for turbo to. You don't have to spend and break the bank at clifford. Tom Langdon from Langdon's Stovebolt has non-tube headers for a much more affordable price and just as good as clifford's.
Old 06-20-2015, 10:20 AM   #753
Texas1963
Texas1963's Avatar
Thanks TJ. And yes it is a toss up between the Cast ones and the Tubes from Cliffords. Also, my 230 runs so damn good I don't want to have my truck down for a long period. TJ, when I come across a 292 what parts(mounts,brackets ect) should I make sure I have so the 292 can just be swapped out. I was reading a new thread about 292 mounts and it got me thinking, is going from a 230 to a 292 a pain or just plug and play? Thanks, and your motor looks awesome.
Old 06-20-2015, 04:18 PM   #754
66Submarine
66Submarine's Avatar
You need a right hand side perch from another 63-66 truck with a 292 and apparently either the right hand block mount with OE spacers from a 292 or another left side mount from a 230/250 with some homemade spacers (I think--I still need to check and make sure). AFAIK the block mounts are the same from 63-72.
Hope this helps!
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 06-20-2015, 04:35 PM   #755
66Submarine
Hope this helps!
It also seems like a 67-72 292 perch (and 230/250, FWIW) may be the same as a 63-66, but I don't know.
Old 06-20-2015, 04:38 PM   #756
66Submarine
I also forgot to mention that some 292's have 1/2" flywheel bolts instead of 7/16".
Old 06-21-2015, 11:59 AM   #757
Texas1963
Texas1963's Avatar
Thanks for the info 66submarine.
Old 06-30-2015, 11:35 AM   #758
rudyyloverboiii
Anyone use steel braided hose for a fuel pump for their 292?
rudyyloverboiii is offline   Reply With Quote
Old 06-30-2015, 06:54 PM   #759
Twisted6
Twisted6's Avatar
I have used it on my 250. And still do for that matter. I have it from my fuel block to my carbs.
Larry /aka Twisted6
Twisted6 is offline   Reply With Quote
Old 06-30-2015, 07:57 PM   #760
rudyyloverboiii
3/8 line? I have a single barrel Rochester carb n I would like to do the same but not order the wrong size hose
Old 06-30-2015, 08:06 PM   #761
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
That Vacuum Manifold off the intake manifold is rare.
Old 06-30-2015, 09:32 PM   #762
TJ's Chevy
TJ's Chevy's Avatar
Haven't yet but Will be on my new engine. lol
Old 07-01-2015, 12:12 AM   #763
'68OrangeSunshine
'68OrangeSunshine's Avatar
Correct. According to Leo Santucci's book, 1966 was the last year for the 7/16'' flywheel/crank bolts on 292s, after that it was 1/2''.
Old 07-24-2015, 11:18 AM   #764
TJ's Chevy
TJ's Chevy's Avatar
Here's a Mean 250 in a chevelle.
https://www.youtube.com/watch?v=KXeBTr8e1mA
https://www.youtube.com/watch?v=vmx6zjqH61g
Old 07-24-2015, 02:33 PM   #765
oldusafmsgt
oldusafmsgt's Avatar
This ones sitting in a 61 C20, 38000 miles when I got it. Dressed it up a bit.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 07-24-2015, 02:36 PM   #766
oldusafmsgt
Just started on this one, 60 C10 short Fleetside
Old 07-24-2015, 05:49 PM   #767
TJ's Chevy
TJ's Chevy's Avatar
Likin those 6 bangers!
Old 09-01-2015, 03:33 AM   #768
Husein-p
Originally Posted by hotrod66 View Post
Just got these cast iron headers today ,any one ells running them ?Attachment 1414138
hi
can i buy this cast iron headers from where ? which sites ?
Husein-p is offline   Reply With Quote
Old 09-01-2015, 06:13 AM   #769
'68OrangeSunshine
Originally Posted by Husein-p View Post
hi
You can get the cast iron headers -- styled like Fentons, but made for the later L6s [230, 250, 292] from Tom langdon at www.stoveboltengineco.com
Old 09-01-2015, 08:20 AM   #770
Husein-p
much thanks
is stove bolt better or this :
http://www.shop.cliffordperformance....rs-52-0011.htm
Old 09-01-2015, 09:52 AM   #771
TJ's Chevy
TJ's Chevy's Avatar
much thanks
The clifford headers Look better imop, but Tom's will Last alot longer. So all in all Langdon's will be the better of the two. Clifford's headers are made of a thicker gauge metal than most headers though.
Old 09-01-2015, 11:02 AM   #772
paintman
I tend to like mine the best.......................LOL
[/URL]
paintman is offline   Reply With Quote
Old 09-01-2015, 11:04 AM   #773
TJ's Chevy
TJ's Chevy's Avatar
[/URL]
Good ole hooker headers! lol
Old 09-01-2015, 03:39 PM   #774
Husein-p
in ur opinion l6-250 engine with 4bbl holley carb + Headers + Lumping port How much horsepower can deliver ?
with standard cam shaft ....
Old 09-01-2015, 04:44 PM   #775
'68OrangeSunshine
much thanks
I've never used Langdon's headers. I talked to Tom in 2002 when I was building up my current 292. He sent me some longer pushrods, my build needed when the Chevy dealer didn't stock them. Long time GM design engineer -- he was part of the team that developed the 230/250/292 series.
So he knows a lot and deals fairly.
That being said: I have had a pair of Clifford Research headers on my truck since 1978. They were on the last 292 for the better part of 250,000 miles [guessing 232,000] before I rebuilt another 292. At the rebuild, I had the old headers hot tanked, and bead-blasted. Then I painted them with VHT hi-temp Gray spray paint. They went on the ''new'' engine in 2005.
I did have the manifold flanges resurfaced in the mid '80s at the same time a crushed down tube [#5 IIRC] from offroad rock damage was repaired. The welder cut out the crushed section and welded fresh pipe over the hole. The mating manifold flange was re-made in 3/8" steel.
I live in the desert, in Tucson, so nothing much rusts badly.
