Old 07-08-2015, 08:01 PM   #1
northerngmc
northerngmc's Avatar
Sat for 11 months, won't start!
My 1968 C20, 396, was parked last August. Parked outside, but in an enclosed shelter.
Last night I charged the battery and it cranks just great today but it won't fire and run.
I was pumped the gas peddle to try and get it to start as I was cranking it. I figured I might have flooded it so I pulled the front left spark plug to check and it was bone dry.
I poured some fresh premium gas down into the primaries. Then it would squirt gas when I pumped the gas pedal. Still would not fire or start. I poured more gas into the primaries. Still won't fire or start. Pulled the front left plug, still bone dry. Pulled the second left front plug to see if maybe it was wet, but again bone dry.
Will pouring gas in the primaries flood certain cylinders while leaving others dry?
I am going to go out later and try again.
I haven't checked for spark but I will this evening.
Any other hints or suggestions?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 07-08-2015, 08:05 PM   #2
Chucks72Longbed
Chucks72Longbed's Avatar
Re: Sat for 11 months, won't start!
It shouldn't. I would get a can of starter fluid and give a small spray down the carb and then run around and give it a try before the ether evaporates. JMO
72 Chevy C20 LWB-Just what I always wanted.
Now, just need more time and money!
Chucks72Longbed is offline   Reply With Quote
Old 07-08-2015, 08:11 PM   #3
Jurassic-1
Jurassic-1's Avatar
How is the gas? If you tried to start it before pouring gas down the carb it could have the jets plugged. Did you check for spark. Stranger things have happened but there could be a spark issue. It only takes Air,Fuel ,And spark to run.
Jurassic-1 is offline   Reply With Quote
Old 07-08-2015, 08:13 PM   #4
northerngmc
Gas is 11 months old, but was parked with premuim and fuel stabilizer. The gas I was pouring in was less than a month old, clean and also premium.
I agree on the 3 things. I will check for spark tonight.
I was thinking if I didn't have spark, I would have wet plugs......
Blaine
Old 07-08-2015, 10:54 PM   #5
franken
Cheap, easy check is a can of spray B12 Chemtool. Open the butterflies and give it a blast. Crank. If it doesn't run for a few seconds, time to check for spark.
The B12 also cleans carbs, removes grease, dissolves paint and skin after a bit, and makes a sweet home flamethrower.
Old 07-08-2015, 11:10 PM   #6
northerngmc
No SPARK!
Cleaned the points and it runs nicely.
Old 07-09-2015, 12:26 AM   #7
Jurassic-1
Jurassic-1's Avatar
Nice when the fix is easy. You may want to drive it to the store to buy a lottery ticket.
Old 07-09-2015, 12:39 AM   #8
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Originally Posted by northerngmc View Post
No SPARK!
Blaine it sounds like its time for a HEI or Pertronix Conversion....
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-09-2015, 12:11 PM   #9
northerngmc
Greg, I am stuck in the points world! Lol
Did your Suburban complete the journey to Saskatchewan?
