Old 07-09-2015, 01:41 PM   #26
MARKDTN
Re: carburation system
Originally Posted by macdodd View Post
I'm using a edlebrook 4barrel system on a 350 with 305 heads and a 3/4 race cam. Wondering if changing to another system would benefit me as far as better gas milege and/or performance?
Yes, throw away the carburetor and add fuel injection. Mileage and power should increase. Either Throttle-Body style or Tuned Port style are relatively easy to swap to and are tried and true systems.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-10-2015, 12:52 AM   #27
mjgord51
Let me ring in here and ask what would the mileage bump up too with both of the fuel injection systems with his engine but with out the 305 heads and going back to some stock 350 heads. mjgord51
mjgord51 is offline   Reply With Quote
Old 07-10-2015, 07:46 AM   #28
MARKDTN
The only apples to apples compare I can give is my own. I have an '83 K20. I got it with 42k miles. It has a 700R4 and 3.42 gears. It always got 14ish in town and 17ish on the road. At about 150k a cam lobe went down. I pulled the engine complete and went to a '90 Corvette Tuned Port 350. Now my mileage is 17+ and town and over 20 on the road. Towing/loaded is noticeably better; with the Q-jet you were always on the gas at the slightest hill. Now just a slight touch and it pulls. That swap is nothing changed-stock manifolds, same transmission and gears. So 3 mpg better which is better than a 20% improvement. That is my experience, yours may vary.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 07-10-2015, 11:28 AM   #29
macdodd
Meant to say,,,,28lbs of pressure at around 3000rpms,,,
macdodd is offline   Reply With Quote
