Old 07-12-2015, 01:06 AM   #1
jtge
New to the forum and new k20
Hi, I'm new to the forum. I just bought a 1967 k20 pickup truck. It has a dying 6 cyl engine. Cylinder compression are between 50 and 70 psi on all cylinders. I'm debating between overhauling the engine, or replacing it with a newer 8 cyl 350. If going the 8 cyl route, will the gearbox/transfer case will be easy to adapt?, or should I keep the I6 and do the overhaul?.
Thanks for the help.
Jose Gonzalez
1967 4x4 k20 pickup.
Guatemala
jtge is offline   Reply With Quote
Old 07-12-2015, 07:28 AM   #2
LMREESE
Re: New to the forum and new k20
It should be a simple bellhousing swap. Can you post pics of the truck.
67 C10 swb bored out 350 granny 4 speed
I come from a long line of moonshiners
LMREESE is offline   Reply With Quote
Old 07-12-2015, 08:48 AM   #3
FlameOut
I swapped out the 250 for a 350 in my 72 K10, and it dropped right in, bellhousing and all. And let's see some pics :-)
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 07-12-2015, 12:16 PM   #4
jtge
Thanks for the help. Which 350 model was the one that fit right in? Carburatted or tbi?
Old 07-12-2015, 12:30 PM   #5
71swb4x4
71swb4x4's Avatar
Bellhousing pattern is the same on 350's, so no concern there.
Try to buy a complete engine with pulleys, brackets, etc.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-12-2015, 12:58 PM   #6
FlameOut
I used a mid 70's 350
Old 07-12-2015, 01:45 PM   #7
jtge
Thanks.
