07-02-2015, 08:10 AM | #26 |
Re: LOST: balancer or pulley
got 'answer' from Damper Doctors, but got confused by the question he asked.
"How many v- belts if more than one how far apart are pulleys 1/2" or 1/4"?"Hereby I attached some photos of the HB which need replacement.. can somebody help? |
07-02-2015, 11:07 AM | #27 |
From your photos, it appears your belt ran on the inside groove of your old balancer. If that is the case, then either of the two (1/2" or 1/4") balancers you mentioned should work.
The choice comes down to availability and selection of the other pulleys if you decide to add P-Steering and AC. I think I would go with the balancer with close (1/4") grooves and figure out what I needed for any additional accessories. Your alternator isn't original, so at some point, someone fabricated its mount to match the balancer.
'67 GMC 2500, 292, 4spd, AC |
07-02-2015, 09:02 PM | #28 | |
Thank you RichardJ
So I will order the 1/4" HB then by the way, would it be easy to replace it by myself? thx a bunch Quote:
07-12-2015, 04:01 PM | #29 |
I guess damper doctor are verry bussy.
Any other recommendation where to buy? It's been long.. So i think i better try dorman HB? http://www.ebay.com/itm/171856161105 Hope to hear some 2 cents Thx Posted via Mobile Device |
