07-15-2015, 01:38 PM | #1 |
Window won't roll down...
My passenger side door window on my won't roll down and it's driving me nuts! I will be taking off the panel this evening to check it out. Before this, the first initial crank was a little stiff then it would just jump into smooth cranking of the window. I have never had to removal the panels before. Anything in particular I should be looking for or need to do?
Any help/info is appreciated...
1970 CST/10 LWB 350 1984 Blazer |
07-15-2015, 01:55 PM | #2 |
Re: Window won't roll down...
Probably change your window regulator
07-15-2015, 01:58 PM | #3 |
look at the little rollers on the window regulator. one might be broken. also lube the reg. mechanism and where the rollers glide. i havea good passenger regulator if you need it
1967custom |
07-15-2015, 02:05 PM | #4 |
The hardest part will be getting the handles off. Here's a pic off a removele tool you can get for under ten bucks and I drew a picture of the c-clip that holds the handles on. The tool makes c-clip removele a 5sec job but you don't need it. You can just use a screw driver or a shop towell and just keep draging it behind the handle until it catches the clip and pops it out. The rest is pretty easy just removing screws. Your window track is made with a rubber insert to hold the window tight. They can start to peel off or get cracked and split and block the window from coming down. You can try to glue one that just falling off. If it really screwed up you can just break off the offending piece and have a shaky window. If you wanna do it right and have a long term fix you can get a new rubber insert. Could be something else but I'm betting on the track insert.
07-15-2015, 02:15 PM | #5 |
Here I was goin out to smoke anyway here's some pics
07-15-2015, 02:16 PM | #6 |
07-15-2015, 02:19 PM | #7 |
I use a shop rag on the door handle clips, just drag it through the gap and it will snag the clip and pull it off.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
07-15-2015, 02:29 PM | #8 |
I lioke tp use a can of wd40 and spray the crap out of the moving parts and see if a bit of cleaning and lubrication will help
07-15-2015, 03:23 PM | #9 |
Thanks everyone for the info! I will definitely give these a go later today! Hopefully its nothing big! Big thanks to Custom/ten for taking the time to post some pics!
I appreciate all the input!
07-15-2015, 07:22 PM | #10 |
Oil all moving parts and the spring too even when these things are wore out will work with little effort
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
07-15-2015, 09:46 PM | #11 |
when in doubt... use more lube !
Better to remain silent and be thought a fool than to open your mouth and remove all doubt. - Mark Twain |
07-15-2015, 09:53 PM | #12 |
X2 on shop rag. I have the tool but use rag.
