Old 07-15-2015, 12:39 AM   #1
Ozzy2013
Ozzy2013's Avatar
C notch or not ?
I am going to put my ford 9 inch on top of the leaf springs on my 68 GMC do i need to notch the frame ?Ive looked all over the forum and internet would love to hear from some one who has done it .Thanks Oz
Ozzy2013 is offline   Reply With Quote
Old 07-15-2015, 09:26 AM   #2
leftybass209
leftybass209's Avatar
Re: C notch or not ?
These trucks led a hard life, and have a varying amount of sag from years of hard use. You may find 10 people who swear you don't have to notch it, but find that you actually do have to notch yours. There's just no accurate information with this stuff. Best of luck with your build.
leftybass209 is offline   Reply With Quote
Old 07-15-2015, 10:34 AM   #3
elimontfort
elimontfort's Avatar
I have a 4 1/2, 5 drop on mine and I still wanted to be able to haul something in the bed besides air. I did the CPP heavy duty notches and couldn't be happier. Granted im not gonna haul a chord of wood in it but I can throw motorcycles, washing machines, air compressors and the like and not worry about beating my axle to death now.
elimontfort is offline   Reply With Quote
Old 07-15-2015, 08:46 PM   #4
Ozzy2013
Ozzy2013's Avatar
Thanks guys i might just do front and rear spring hangers .We used to have a spring manufacturer right up the road in Delaware .But he sold out and the business is no longer there paid 200 for a set of springs many a time!I hate forking out 400.00 for a set of springs would love to have a mono leaf set up for better weight transfer im building a hot rod wont be hauling anything in the truck .I might just build a four link set up and bag it if i notch it .
Old 07-15-2015, 08:54 PM   #5
67 chevelle
67 chevelle's Avatar
Im sure you would be happier with the 4 link and coilovers
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-15-2015, 09:50 PM   #6
Ozzy2013
Ozzy2013's Avatar
Ive been searching every where for a set of front rear spring hangers to lower it 2 inches and then use 2 inch lowering shackles for the back .That would work perfect!
Old 07-15-2015, 10:00 PM   #7
Mike C
Mike C's Avatar
Nobody makes hangers for the early trucks and their 2 1/4" springs. I flipped mine and netted 7" drop. Removing the overload and going with ECE shackles gets 2 1/4" drop. Otherwise, keep your axle where it's at and just suck it up and buy 4" drop springs. I did 2 1/2" spindles and 2" springs in the front so it's a 4 1/2"/7" drop.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-15-2015, 10:33 PM   #8
Ozzy2013
Ozzy2013's Avatar
Im using a 9 inch and it has 3 inch tubes and by the best measurements i can do it looks like ill end up with about 4 .So i don't think ill need a notch kit .I have it down to the frame right now so ill get the bed on it tomorrow set the motor and trans in set the cab and see where it sits .Was hoping someone had done a ford 9 inch and flip and no notch trying to get everything done and ready to go in ill build the rear and not weld the spring purchases yet that way i have the option of putting them top or bottom i can make my own front hangers too .No big thanks all for your input greatly appreciated !I wonder id 3 front and 4 back will look good ?
