Old 07-20-2015, 06:07 AM   #1
cjoenny89
cjoenny89's Avatar
new door seal installation
I am installing new door seals that mount to the cab. This is being a pain in the but! Is there a good way to do this? I tried starting in the "square" corner and taping it in place but it keeps pulling down. What is the proper way to glue the seals into place? can you just use a silicone? I can get all the scrap silicone I want from work. what have you guys used and have you used masking tap to help hold it into place while the glue dries?
Chad
cjoenny89 is offline   Reply With Quote
Old 07-20-2015, 08:12 AM   #2
volksworld
Re: new door seal installation
just to kinda go off on a tangent there are a lot of door seals out there that are too thick and the door won't close so i suggest you just tape them in place first to make sure they're ok before you have 8 feet of glue to scrape back off..the third set i bought actually worked...there are also push on types that dont require glue but these are also thicker and might be hard to close (mine were already installed before i found ouy about those)normally you put them on with 3m weatherstrip adhesive,not silicone
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-20-2015, 08:30 AM   #3
cjoenny89
cjoenny89's Avatar
So like a 3m 2 sided tape?
Old 07-20-2015, 09:09 AM   #4
kolle_hond
I bought the black sealant/glue that they recommended with the door rubbers on LMC. I didn't know you get different thickness, but the seals were as thick as the old ones, so I also started on the corner, and just glued from the start. You might have to stand there holding the rubber in place for 3-5 minutes, but then you just go from there. Remember to cut a hole/slot where the two ends meet for the door to close easier.
1970 C10 250 3-speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=650480
kolle_hond is offline   Reply With Quote
Old 07-20-2015, 09:16 AM   #5
cjoenny89
cjoenny89's Avatar
What exactly do you mean hole/slot? Can u send a picture? Don't you just butt splice them together
Old 07-20-2015, 09:18 AM   #6
cjoenny89
cjoenny89's Avatar
Did you put glue on the inside and outside of the cab rail?
Old 07-20-2015, 09:20 AM   #7
Sklptrljay
Sklptrljay's Avatar
I used push on door seals from a 90's truck from the junkyard. $10 and 10 minutes.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 07-20-2015, 09:29 AM   #8
geezer#99
geezer#99's Avatar
Pain in the butt job!!
Use the 3m adhesive.
Start at the top. Line it up so the part line is on the door sill. Mock it up.
Put the 3m in the groove. Only about 6 inches at first. Push the rubber onto the rail. Pull it away slightly and back into place. Keep doing that until the glue on the channel sticks to the rail. You need to bond the glue in the channel to the glue on the rail. And get the air out from between. You'll hear the air squish out. It'll stay in place, but it takes awhile. If it starts to sag, just work it on and off slightly. Once that piece stays in place, do another 6 inches right beside it. It might take 2 to 3 hours per door.
Old 07-20-2015, 04:31 PM   #9
midniteblues
midniteblues's Avatar
http://67-72chevytrucks.com/vboard/s...489394&page=11
see post 265. these worked well for me
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 07-20-2015, 11:46 PM   #10
trkfrk
trkfrk's Avatar
I used 3M Hi-Strength Adhesive and plenty of tape. Worked very well.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 07-21-2015, 08:17 AM   #11
volksworld
from the factory they were only glued on the outside...leave a little gap under the sill plate to let the air escape
Old 07-21-2015, 10:49 AM   #12
cjoenny89
cjoenny89's Avatar
thank you all for the help I hope to have it installed soon! I got my carpet in last night what a job that was!
Old 07-22-2015, 09:19 AM   #13
kolle_hond
Sorry for taking so long with a picture. I only learned about the notch you need to cut out after the seal was already installed, that's why my cut was a bit choppy. I'm still planning to remove the rust/get new step sills, so you can ignore the ugly rusted stuff.
Old 07-22-2015, 10:07 AM   #14
cjoenny89
cjoenny89's Avatar
thanks I would not have left a gap!
