07-22-2015, 09:30 AM | #1 |
Mounting holes for sport mirrors?
My '70 had no mirrors on it when I bought it, although it appears that someone had sport mirrors on it at some point. Since I am going to have a 71-72 front fascia on it I wanted to run sport mirrors anyway, but when I removed the paint I realized the PO had plugged the original mirror holes with bondo and they are much larger than the holes that had been drilled for the sport mirrors. I am plugging those, but do they need to be the same size for the sport mirrors? I ordered new mirrors from brothers and they have a backing plate and some small stainless screws so it doesn't look like I need to have bigger holes, but I wanted to make sure I'm not missing something. I'd like to drill any holes BEFORE going to paint.
07-22-2015, 10:14 AM | #2 |
Re: Mounting holes for sport mirrors?
took this from this board
07-22-2015, 11:58 AM | #3 |
Thanks! Somehow I never came across that pic when I was searching
07-22-2015, 12:14 PM | #4 |
Probably the best post out there for this. Let us know how it turns out, I have to do mine as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=179279 Incidentally, I've read where that 35" reference point should be 30" from the bottom of the rocker panel. I believe that's from the lower "body" of the rocker panel, not the edge on the back of the rocker panel, but it would be nice to confirm this. It would also be interesting to see if based on which the correct measuring point is, that the hole for the front mirror screw is 1" below the rim of the door, as demonstrated in the link provided above.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-22-2015 at 12:53 PM. |
07-22-2015, 02:02 PM | #5 |
I used these dimensions and everything worked fine. Notice the right mirror will be further back than the left mirror. Truck looks way better than the camper mirrors on before.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
07-22-2015, 03:39 PM | #6 |
Side note- I just got my sport mirrors installed, and I'm so glad I kept them. I almost got rid of them to go with an aftermarket mirror. The sport mirrors look nice and are very functional.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
