Old 02-23-2015, 08:01 PM   #51
liftlawssuck
liftlawssuck's Avatar
Re: How to restore the 4x4 Blue Front Hub lock knobs?
I've soaked some that aren't too bad in oil. As long as it's not real white it comes back some. Not nearly new but it made mine back into almost new. Might weren't that bad though.
liftlawssuck is offline   Reply With Quote
Old 02-23-2015, 11:09 PM   #52
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
I've got the K20 ones reverse engineered and just need to find a reasonably priced guy with a CNC. These are in CAD (obviously) so I can export pretty much any file type for CNC or rapid prototyping.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 07-30-2015, 05:25 PM   #53
CUSTOM/10
CUSTOM/10's Avatar
I had a few mins today so I messed around with some blue lock-out dials to see what a torch could do to the chalky white faded dials. I cleaned them up, ( with very fine sand paper ) sanded any areas that needed it, then using a hot torch I
very quickly passed the flame back & forth over the dial allowing the flame to touch the plastic only for a fraction of a second at a time, slowly melting the white chalky plastic back to blue ! There not perfect, but much better than before ! What do you think ?
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 07-30-2015, 11:49 PM   #54
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Just be careful. I did that with a heat gun before on a set. They melt really easy as the handle holes don't get as warm as the outside perimeter. Be very careful if using this method. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-31-2015, 06:52 AM   #55
CUSTOM/10
CUSTOM/10's Avatar
Hey Trevor !
Yeah, I have a few extras that I practiced on first. I found that using a very tiny tip for the recessed areas first, then a larger tip for the rest worked well.
But your right, you need to be very careful.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 07-31-2015, 07:05 AM   #56
jaros44sr
jaros44sr's Avatar
nice
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-31-2015, 07:26 AM   #57
CUSTOM/10
CUSTOM/10's Avatar
One of those was from you Jim !
Thanks Again !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 07-31-2015, 07:58 AM   #58
FlameOut
Some good tips here. Definitely gonna attempt to clean my weathered looking knobs
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 08-01-2015, 08:51 AM   #59
jaros44sr
jaros44sr's Avatar
Thanks Again !
Gary
Your welcome, glad you could use it
SAFETY FIRST
AS usual, off topic
Jim
