Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 09-04-2015, 01:18 PM   #1
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
1966 Suburban...Sort of...Trailblazer SS SWAP
Here is a little background on my most recent project. In May, 2015 I purchased a Trailblazer SS locally as a doner vehicle. At that time, I wasn't completely sure what Body I was going to use. My intent was to use as much of the Trailblazer as possible. Since this vehicle came with a 400hp LS2, 4l70E trans, 4 wheel disc brakes (Drilled and slotted rotors), nice 20' Wheel with good tires, leather interior, all wheel drive, etc I felt that buying this as a doner vehicle was most likely more cost effective than sourcing all of these parts individually. The price was right on the SS, so I pulled the trigger. I will remove all of the SS wiring, run stand alone engine and transmission computers and wiring harness from PSI.
A few weeks later I found a '66 Suburban body for sale. After verifying a few critical measurements (wheelbase, track width, distance from firewall to grill) I decided a 60 to 66 Chevy would fit pretty well. That was good news for me, as I have owned at least a half dozed of these in either the truck or suburban form. I picked up the Suburban and started cutting...
Over the last few months I have repaired rust down the driver side of the Suburban, and shortened the body 3" so the wheel wells would line up with the SS. I actually only needed to shorten it 2", but noticed that the wheels seem to line up better on these when an additional inch is removed. Same amount of work, so why not?
Last weekend I removed the entire steel floor section from the Suburban. I will remove the wood floor soon, but wanted to leave as much structure as possible there. My reason for removing the floor from the suburban is I will utlize the floor and firewall from the trailblazer. It allows me to channel the burb as low as I want, retains the proper brake booster, steering shaft locations, as well as seat anchoring points, and NO RUST!
I have just started the process of dismantling the SS. I will cut the body off down to the inner rocker panels and firewall, then drop the burb body over the SS and begin the process of filling the gaps and extending the SS floor bracing to the burb inner rockers.
While this is alot of work, its the kind of stuff I like to do. Its really not difficult, just alot of measuring, cutting and welding.
I will post up pics as I progress. If you have questions, post 'em up!
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 09-04-2015, 01:20 PM   #2
Eagletucky
Eagletucky's Avatar
Re: 1966 Suburban...Sort of...Trailblazer SS SWAP
Pics....
Old 09-04-2015, 01:41 PM   #3
Clyde65
Clyde65's Avatar
HOLLY RABIES! that is sick and cool! Im along for this one for sure!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-04-2015, 01:45 PM   #4
Layne
Very cool project
Layne is offline   Reply With Quote
Old 09-04-2015, 04:50 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
this gonna be cool!
I remember your last build came out nice. signing on...
Old 09-04-2015, 08:39 PM   #6
This is going to be a very interesting build.
Old 09-04-2015, 09:01 PM   #7
flashed
Im in .
flashed is offline   Reply With Quote
Old 09-05-2015, 12:41 PM   #8
65sub
65sub's Avatar
Old body on a new base. Sounds like a cool idea
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 09-05-2015, 03:19 PM   #9
Free Candy Inside
This is going to be kickass
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 09-05-2015, 03:23 PM   #10
wjjeeper
wjjeeper's Avatar
Watching closely here too
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 09-05-2015, 06:50 PM   #11
Eagletucky
Eagletucky's Avatar
I had a very productive day!!!
I drove this to McDonalds for breakfast today, no joke.
Old 09-05-2015, 06:50 PM   #12
Eagletucky
Eagletucky's Avatar
Sorry, wrong pic
Old 09-06-2015, 12:43 AM   #13
Captainfab
60-66 Nut
I'm shocked at cutting up a Trailblazer SS, but I imagine there is reason for that versus driving it as is.
Old 09-06-2015, 12:47 AM   #14
Zane M
Looking forward to this as it progresses.
Zane M is offline   Reply With Quote
Old 09-06-2015, 08:02 AM   #15
Down here they would not think twice about seeing that in the drive thru.
Old 09-06-2015, 09:11 AM   #16
wjjeeper
wjjeeper's Avatar
Wow. That happened fast.
Old 09-06-2015, 09:30 AM   #17
ibrown50
ibrown50's Avatar
In the words of Billy F Gibbons "anyone can put one back together, but it takes a real man to cut one up"
I'm signed up!
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 09-07-2015, 10:55 AM   #18
donthekawguy
donthekawguy's Avatar
Well that escalated quickly! LOL Takes big brass ones to cut up a 20k rig!
66 shorty
donthekawguy is offline   Reply With Quote
Old 09-07-2015, 11:03 AM   #19
pimpston65
pimpston65's Avatar
what did you do with the old burban floor?
pimpston65 is offline   Reply With Quote
Old 09-07-2015, 02:47 PM   #20
Eagletucky
Eagletucky's Avatar
Gave it to a board member, trying to pass on the good will i have recieved in the past.
Old 09-20-2015, 06:10 PM   #21
Eagletucky
Eagletucky's Avatar
Alright, back at it today. I finished removing the remainder of the sheetmetal. Funny thing, it took 4 hours to remove 90% of the body, and two weeks to remove another 5%.
So at this point, im ready to begin welding in the 2x4 box tubing along the rockers to create the structure to connect the two bodies. I may actually have to remove the burb rockers, to install the box tubing, no big deal.
Anyhow, here is a picture, more info to come
Old 09-20-2015, 07:38 PM   #22
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Wow!
All that I can see there is commitment!!!!
You must be pretty sure about this, or you are gonna have a bunch of scrap layin around!
I am pretty impressed so far!
I can't wait to see this build develop!
Modges'66 is offline   Reply With Quote
Old 09-21-2015, 09:43 PM   #23
ricott
I'm in, can't wait to see the body get fitted.
ricott is offline   Reply With Quote
Old 09-21-2015, 10:36 PM   #24
matt_l
Wow, I can't wait to see this one come together. The members of this board never cease to amazing me. So much skill and creativity.
Matt
Father Son 66 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=564694
matt_l is offline   Reply With Quote
Old 09-21-2015, 11:54 PM   #25
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Very cool. Im in.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
