70+ ( Old Skool Club )
![]() Join Date: Nov 2003
how Important is This?
How important is the Air Spacer thing that goes between the Air Cleaner and carb and what does it do? Is there some kind of filter that that is on the bottom part that plugs into the valve cover. Will it hurt anything if I remove the air spacer as I may want to go with an Edelbrock Air Cleaner and valve covers or stock looking dual snorkel air cleaner.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Sep 2007
Re: how Important is This?
doesnt it act as a breather? i inagine you could put a breather in the valve cover and bypass that. ans a pvc on the other valve cover
1967custom |
![]() Join Date: May 2013
As long as you run a pcv you will be fine , don't cap it off or leaks will follow , and will be significant
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
![]() Join Date: Mar 2005
My truck has one and a PVC valve on the other valve cover. I just left it in place and put a chrome 14" open air filter on mine. Lots of clearance under the hood.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
If you get rid of the crankcase vent/spacer, you would replace it with something like this:http://www.knfilters.com/vent.htm (crankcase breather filter).
Healthy engines pull air in through this device...but, my engine pushes air out (can you say blow by). Engine still idles great, pulls great, burns a bit of oil (nothing visible while running) so I don't worry about it. For my truck, the air filter housing will to fit directly on the carb (Qjet) and still clear other engine components. |
So the open element Air Cleaner can sit a top the air spacer like the stock air cleaner, then I can just leave things the way they are. Never thought of that. I want to put the Edelbrock Elite Valve Covers ( to match the air cleaner) on too but have to check and make sure there are enough holes for the PCV Valve, oil fill and the air space breather in them.
I'm pretty sure your truck will explode if you don't have that!
![]() Seriously though, it's not necessary in that configuration, but your truck needs pcv in some form. |
Does it need a PCV on both valve covers because there is a PCV on the drivers side.
no just a pvc on one side and a breather on the other. like one of them chrome mushroom shaped ones they sell in the performance section at o'reillys
1967custom |
As stated, just one pcv system is necessary. A breather should be on your opposite valve cover. Since your engine looks fairly stock, you may consider setting up your crankcase ventilation stuff as it was originally, but not necessary.
Well in Ontario having that removed and a push in breather is a ministry of environment fine of $350. If you get caught. Its designed to burn off the vapours from the engine.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Its not problem in fresh air Saskatchewan as we have no emissions testing or mandatory safety checks unless the vehicle has never been registered in Saskatchewan. Whats real nice is anything that is 30 years or older being brought into the Province doesn't require an inspection of any kind.
