09-22-2015, 03:30 PM | #1 |
Front bumper bolts question
71 Chevy
There are six bolts that mount the front bumper to the brackets. If you look closely, the heads on two of these bolts are more rounded than the other four. The other four come to somewhat a peak, similar to the mushroom in this link (ha!). http://pngimg.com/upload/mushroom_PNG3186.png I think the two more rounded heads are for the top center. Can you confirm or correct? Didn't see it when I took them off.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-22-2015, 03:33 PM | #2 |
Moderator
Re: Front bumper bolts question
All six bolts are the same.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-22-2015, 03:56 PM | #3 |
Parts and more parts
The bolt heads will differ with the manufacturer. Get a full set form one source and replace the old ones so that they all look the same.
Frank |
09-22-2015, 05:23 PM | #4 |
The bolts are all the same from the factory// i think that your bumper may have had bumperrettes on it at some time and somebody lost or destroyed some of the originals
09-22-2015, 05:49 PM | #5 | |
The original owner had a slot cut out from the bumper and a boat launching hitch welded to it. Shame, the bumper is probably worth recycle only.
09-22-2015, 06:21 PM | #6 |
I believe the original GM carriage bolts have a higher dome than any replacement that I have seen so far
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
09-23-2015, 12:24 AM | #7 |
Are the front bumpers on a 1968 chevy C10 the same for a 1968 GMC C1500? The one on the GMC needs to be replaced.
Thanks in advance for any info. |
09-23-2015, 01:48 AM | #8 |
Not so sure about the '68 [and '67] GMCs but later GMC bumpers had those rolled-back rims under the Turn Signal/Parking Lamps so the bumper didn't eclipse half the running light. Chevys had those lights higher in the grille or '71 -'72 in the bumper itself.
Other than the cut-outs, the GMC bumper should be just like the '67-'70 Chevys.
09-23-2015, 11:28 AM | #9 |
I have my 1972 bumper off and the carriage bolts are unique (in my mind) in that the shiny heads appear to be due to a thin metal wrapped over the top and tucked into the underside of the head. I can see its edge under there.
All my bolts are uniform in shape. |
