Old 09-22-2015, 03:25 PM   #1
68C15
blood type; Retumbo
68C15's Avatar
Tell me about these firewall markings
I was reading the thread about production lines and something about the markings. What are they and what do they mean. Is there some secret code for reading them? Mine don't match the VIN.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-22-2015, 03:46 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Tell me about these firewall markings
Post some pics.
Usually they are option codes, or a heads up for downstream workers on paint colors and such.
http://67-72chevytrucks.com/vboard/s...light=sequence
http://67-72chevytrucks.com/vboard/s...light=graffiti
They will not match the VIN. Nobody in the vehicle assembly plant cares about the VIN - everything is keyed off the build sequence (or manifest sequence) number. The build sequence number is an attempt to control the flow of subassemblies into the main line, and keep everything in order.
The VIN is just a part to be installed on that particular build, just like a tune up label, SPID label or Mulroney window sticker.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-22-2015, 03:49 PM   #3
Keith Seymore
My truck happened to be "number 87" -
VIN is HFxxx388.
K
1979-1986
1986 - 2019
Old 09-28-2015, 06:48 AM   #4
Keith Seymore
Did that answer your question? Other questions?
K
1979-1986
1986 - 2019
Old 09-28-2015, 08:32 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
I'm talking about the ones on top of firewall by wire channel.
There was also some hint of that being related to fixes or some small defect I think
Old 09-28-2015, 10:01 AM   #6
Keith Seymore
Yah - option content. I've seen model number, engine RPO, trans RPO and brake system option.
Not related to fixes. Repairs are logged on a specific repair ticket and then "bought off" by the repairman (and inspector) by using a hole punch with unique characters (hearts, moons, clovers). The characters can be traced back to the particular repair person or inspector if need be.
The repair tickets are bundled together as the vehicle goes through the build process and then are thrown away once the vehicle is shipped.
Repairs are not normally written on the vehicle itself.
K
1979-1986
1986 - 2019
Old 09-28-2015, 10:18 AM   #7
Keith Seymore
One more, related to this list:
http://67-72chevytrucks.com/vboard/s...91#post7318891
1979-1986
1986 - 2019
