Steering Column Removal
After I have the steering wheel off of my '59 GMC Fleetside , how do I get the column itself out . All the brackets and clamps are loose or removed yet it wont break free from the steering box . Am I missing something ? Bob.
"Treasure the Ride"
You have to try some penetrating oil. Let it soak for a few hours then repeat the process. Sounds like the splines are rusted on.
my two cents worth. rico_bob
If you think you can you're right. If you think you can't you're still right. Trucks: '56 SWB; '57 SWB; '63 C-10 Current projects: 1963 Long Fleetside for the wife! '56 for the daughter. Visit us at: www.ricos-rods-and-relics.com |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
After the soaking it like Rico mentions, try some wiggling and convincing.
Do not beat on it with a hammer. That could damage the steering gear and column ![]() |
Steering Removal
In your post you mention using penetrating oil and letting it soak , question is all I have is the frame itself with the steering column , steering wheel and the cab etc is all removed . Where is it I'm supposed to place the oil in order to get the shaft free of the steering box ? Thanx , Bob.
"Treasure the Ride"
Are you planning on re-using the steering box?
Fleetside, I think the column tube is simply pressed into the steering gear housing. The penetrating oil should go at this joint.
-dch |
