#301 |
Re: What did you do to your Blazer/Jimmy today?
My paint looks better in pictures than it does in real life.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#302 |
Did stock coil springs, shocks, brakes, B hoses on the 72 GMC Jimmy 2WD TODAY! Did body bushings, fan clutch, fan and 4 core radiator last week or so.
Trying to get it ready for paint next month. BB
No one gets out of here alive. |
#303 |
![]() Join Date: Jun 2002
Put my column together (3 times...) and test fitted the steering wheel.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
#304 |
Nicely done, I like the wheel, never saw one like that. Who makes it. My horn button keeps falling off, gotta buy a new mounting kit
#305 |
Thanks! The wheel is one of the GM comfort-grip sport wheels from the 70's. You can find them on ePay (I actually bought mine on here). The horn button is from a Buick GS, I just removed the center emblem and put one in that I had made (some place on the internet that will make just about any round emblem in any size you want).
Rg
#306 |
That white blazer is awesome. I walked around it no less than ten times, dragging my lower jaw the whole time. It's an older build that was tastefully done. Dave wouldn't trade me for my 68 no matter how badly i begged.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R Last edited by gottattooz; 10-08-2015 at 11:28 AM. |
#307 |
![]() Join Date: May 2006
I backed out of the shop to do some more sanding, I may actually get some paint on this thing yet.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
#308 |
Looking good
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
#309 |
Love the Jimmy's with the 67 dog house. What color are you thinking of?
#310 |
Air inlets look good on there, so you backed it out, must be running. Have driven it around the block yet? Glad you're still working on it. More pics?
#311 |
Mounted the bench seat and test fit the half top. Handled the top by myself, but I think I'll get help next time...
I haven't drilled and bolted the bulkhead yet, just trying to make sure everything is going to fit. Rg
#312 |
Jealous, I want one so bad!
#313 |
Still debating, I'm looking at a two tone silver with a charcoal stripe right now.
#314 | |
Some of the front end problems will go away when I get new tires and shocks. The header to exhaust pipe gave me some problems but I got that solved. I'm ready to start driving and quit workin'. ![]()
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! Last edited by RustyParts; 10-26-2015 at 09:23 AM. Reason: added info |
#315 |
That top will help heat the interior during the cool Kentucky winters. I'm right up the road from you just south of Owensboro. The only problems I had with my half cab were water leaks and the window weather strip didn't snug up very good. Good Luck.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! Last edited by RustyParts; 10-26-2015 at 09:37 AM. |
#316 | |
Thanks, Rg
#318 |
Carpe manana
![]() ![]() Join Date: Dec 2010
The slider windows in the half-cabs resemble a factory unit for the pickup. I just rebuilt another one today (first one here: http://67-72chevytrucks.com/vboard/s...d.php?t=559651) for use in my K1500 - am curious if the weatherstrip is easy to redo on the half-cab units. GM factory sliders have screws that hold the frame pieces together in the corners, and the pieces are not welded together.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#319 |
Put A roll pan on the front, ran out of gas for the welder. Another trip to the city.
#320 |
Looks sweet!
#321 |
Finished bucket seat brackets finally! Now ready to go into the toy!
#322 |
Stuck the hubcaps on and picked up the seat from the upholstery shop. They said the 1988-1994 seats are very hard to do. Probably should have waited on having the seat done as now I have to keep from messing it up until I'm ready to install it.
#323 |
![]() Join Date: Oct 2015
Started putting color on stuff today.
#324 |
![]() Join Date: Jan 2013
Working on my top delete doors for the summer. CST top delete "ya right"
#325 |
![]() Join Date: Nov 2009
New heater core.
71 Chevy blazer. (Modified) |
