Old 10-13-2015, 01:02 AM   #1
dacavy
1971 Super Cheyenne build
This is my first frame off restoration. I had this in the main forum section but it was suggested to start a build thread. The truck is a 1971 super cheyenne long bed. Big block 402 with turbo 400 trans. I am shortening it, lowering it... etc. Its going to be a daily driver for awhile. Let the good time begin. I started this project in April 2015.
dacavy is offline   Reply With Quote
Old 10-13-2015, 01:04 AM   #2
dacavy
Re: 1971 Super Cheyenne build
Body was in decent shape. Rust in rocker and cab corners.
Old 10-13-2015, 01:09 AM   #3
dacavy
Cut the bed and frame. Welded her up.
Old 10-13-2015, 01:11 AM   #4
dacavy
Frame and cab sandblasted
Old 10-13-2015, 01:14 AM   #5
dacavy
Found a hidden gem in my fender. Almost 1/2" of bondo in some place. I had an extra fender with damage in a different place so I just used the good part.
Old 10-13-2015, 01:16 AM   #6
dacavy
Going with ECE 4-6 drop kit and Ridler 695 20" rims.
Old 10-13-2015, 01:18 AM   #7
dacavy
Had the 402 rebuilt. Pretty much a stock rebuild with new intake, headers, hei. Transmission was already rebuilt by previous owner so I just cleaned it up.
Old 10-13-2015, 01:20 AM   #8
dacavy
And this is where I am now. Cab is epoxy primered, next up...bed,fenders, hood.
Old 11-15-2015, 10:50 AM   #9
kitsbeach
kitsbeach's Avatar
You make it look easy..!!
Just wondering about your frame cut. I saw another post I thought was by you where it was only a 2" step notch.? I was looking for that build as I want to leave my cab on when I cut my frame.
Here is the one from this thread:
And here is the 2" cut from the other thread:
Name:  2 inch step cut.jpg
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is online now   Reply With Quote
Old 11-15-2015, 11:47 AM   #10
dacavy
Because I took the cab off to sandblast the frame, that's why I cut under the cab. The red truck I didn't want to pull the can. If you start your cut right behind the mount you can get your 12" no problem. Then you have to move your crossmember.
Old 11-16-2015, 09:34 AM   #11
Farm Shop
Farm Shop's Avatar
Nice metal work! Keep the pics coming.
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina
1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208
1970 GTO Judge, heads/cam LS1 & stalled 4L60e
Farm Shop is offline   Reply With Quote
