Old 12-04-2015, 12:42 AM   #1
hpcgmc
hpcgmc's Avatar
are all 67-72 roofs interchangeable?
I've got a sunroof hole in the roof of my 67 GMC. My welder guy can patch it, but prefers real sheet metal over the replacement panels.
Any ideas if the roofs changed over the years? I just need the center section of the inner and outer roof. I assume they didn't change at all, but thought I'd better ask before buying something that won't work.
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 12-04-2015, 12:55 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: are all 67-72 roofs interchangeable?
All the same except for the ones that have the cab light pods on them.
LockDoc
Leon
Old 12-04-2015, 02:36 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Leon, you know far more about these trucks than I ever will. However.... my '72 has a steel inner roof. Didn't some of the earlier trucks have a non-steel headliner panel? And isn't there a minor difference where the inside mirror mounts? Or maybe I'm misunderstanding the question....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-04-2015, 10:54 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
Don't forget cargo light vs non cargo light.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 12-04-2015, 11:27 AM   #5
Homes have roofs and vehicles have tops. I know, picky picky. But, yes, all 67-72 tops exchange. There are features some had that others didn't, but the outer top panel is the same stamping...other than 69-72 clearance lamp mounts. The inner panel is a separate piece, but all are the same stamping, except for headliner truck panels having the slots for the headliner moulding to mount
Old 12-04-2015, 11:27 AM   #6
drewbert41
drewbert41's Avatar
Well there is big rear window/ little rear window.
Also, no one sells a repro inner roof skin.
drewbert41 is offline   Reply With Quote
Old 12-04-2015, 11:43 AM   #7
hpcgmc
hpcgmc's Avatar
Thanks guys. I don't need the cab lights or the headliner stuff, just the center section of the roof (aka top). Looks like I can buy anything off a c10, which is what I needed to know.
Thanks!
Old 12-04-2015, 12:17 PM   #8
LockDoc
LockDoc's Avatar
Since he said in his original post that he only needed the roof center cut out, the only thing that would apply would be the interior headliner which would be very visable when looking at one. All of the other differences would not apply. If he had said he was replacing the entire roof I would have mentioned all of the other differences....
Thanks,
LockDoc
Leon
Old 12-04-2015, 12:52 PM   #9
EARNHARDT#3
EARNHARDT#3's Avatar
Then where on a vehicle do you put a roof rack?
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 12-04-2015, 12:54 PM   #10
drewbert41
drewbert41's Avatar
Post pics of the repair afterwards!
Old 12-04-2015, 02:05 PM   #11
Redline novdog
Redline novdog's Avatar
X2. If I keep my '67 it will eventually need a whole cab restore top/roof included!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 12-04-2015, 02:47 PM   #12
hamjet
hamjet's Avatar
Originally Posted by earnhardt#3 View Post
then where on a vehicle do you put a roof rack?
on the top...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 12-04-2015, 08:13 PM   #13
The rear window is in the back panel, separate piece. He's just doing the outer skin. If the outer is the roof then the inner is the ceiling.
In the bed . On a hardtop or a convertible? Convertibles can't use them because the "roof" is fabric. Both ways work but I prefer to use different terminology for vehicles and buildings. Convertible top, vinyl top, soft top, drop top, chop top, open top, half top.
