Old 12-21-2015, 02:58 PM   #1
Foot Stomper
Foot Stomper's Avatar
Saddle tanks on a Task Force?
After much searching I haven't been able to figure out if anyone has ever tried and/or succeeded in mounting saddle tank(s) on a '58 or '59 Task Force Fleetside. I understand a rear mounted tank is popular, but I'd like to consider saddle tank(s) to avoid having a bed style filler.
I am also wondering anyone has fabricated a "behind the tail light" filler on a 58 or 59 Fleetside? The tail lights are certainly large enough to hide it for sure.
The main reason for removing it from the cab is to make enough room for an overnight bag or two. With the tank in the cab, there's no chance of that!
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 12-21-2015, 06:55 PM   #2
_Ogre
_Ogre's Avatar
Re: Saddle tanks on a Task Force?
suburban/panel truck tank would work, but no one repops them and they are rare as hen's teeth
shop air compressor timer
Old 12-21-2015, 09:11 PM   #3
OrrieG
OrrieG's Avatar
inlet pipe does not have much slope, but you can do a side mount.
Old 12-21-2015, 09:30 PM   #4
Foot Stomper
You've nailed the challenge Ogre!
The side spears thwart the height. (New word I'm trying out). I don't mind the side fill at all except I'm concerned about the height so was thinking hinged hidden tail light access.
Would the tank from this donor work?
Old 12-21-2015, 09:55 PM   #5
57chevyman
57chevyman's Avatar
behind license plate.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 12-21-2015, 10:04 PM   #6
Foot Stomper
That could work too but what about the height of the filler neck...is it high enough? I'm assuming it is but have to ask. What kind of tank did you use?
Old 12-21-2015, 10:26 PM   #7
57chevyman
57chevyman's Avatar
i used a '65 mustang tank from Tanks Inc.
the filler neck is high enough...not ideal..i have to be careful and not fill at full speed. i keep a shop towel handy just in case, and i fill up with no problem
Frank
1957 Chevy 3100
Old 12-21-2015, 10:35 PM   #8
mr48chev
mr48chev's Avatar
I think If I was to run the rear fill under the back of the bed I'd want to run a non vented cap and then run a vent hose with a little filter on it up in one of the stake pockets to get it up several inches above the top of the tank. That way you should be able to get away from the gas slosh problem on acceleration that we often had with tanks that filled behind the license plate in the late 50s and early 60s.
My ongoing truck projects:
Old 12-21-2015, 10:43 PM   #9
Foot Stomper
Good point!
My 1969 Oldsmobile 442 had a behind the plate tank filler! Talk about acceleration!
Old 12-21-2015, 11:27 PM   #10
Northern lights
I had a rear tank on my '64 fleetside with the filler behind the tail light. It sucked. On mine, the light just had two thumb screws that you unscrewed and pulled the light assembly out. That was OK but, even though the filler is mounted high, the neck still had to level out under the box to get to the tank and was a pig to fill. It took FOREVER to dribble the fuel in. Took the whole thing out and put the tank back behind the seat like the general intended. Personally, I LIKE the way these trucks were designed asthetically from the general and, if I needed that space behind the seat, I would have a custom aluminum tank made that went ahead of the diff and stradled the drive shaft (kinda like joined saddle tanks) and fabricate a filler neck that used the factory cap location and went through the floor behind the seat to the tanks.
Northern lights is offline   Reply With Quote
Old 12-21-2015, 11:27 PM   #11
57chevyman
57chevyman's Avatar
my tank came with a vent hose next to the feed hose
Frank
1957 Chevy 3100
Old 12-22-2015, 06:49 AM   #12
tmoble
what's that black cylinder thing on the rear of the frame rail?
clean setup there.
tmoble is offline   Reply With Quote
Old 12-22-2015, 08:09 AM   #13
57chevyman
57chevyman's Avatar
clean setup there.
oh thats just a piece of rubber hose that came with the kit laying there
Frank
1957 Chevy 3100
Old 12-23-2015, 11:07 AM   #14
Foot Stomper
Thanks Northern Lights! You're input is much appreciated! Your preferred choice of original fill neck to tank over diffy is one that I would like to see if anyone has pictures of the set up.
I appreciate all the replies!
I started looking at different gas tanks and found some interesting options? including motorcycle tanks and 4wdr tanks for the RZR etc that may be able to be fabricated to make work by using two of them. The search continues!
Old 12-23-2015, 12:09 PM   #15
Dan in Pasadena
Dan in Pasadena's Avatar
Frank,
How did you/where did you terminate the vent hose? I guess I've never really thought of venting before but makes sense that I'll have to have one.
The suggestion to terminate it in one of the stake pockets seems good but I'd have to put something on the end to keep miscellaneous "stuff" from falling into it, I guess.
Also, is that a standard elbow provided by Tanks, Inc? No issue with the gas eating the rubber hose so far?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 12-23-2015, 12:14 PM   #16
_Ogre
_Ogre's Avatar
you'd have to measure to see if it would avoid the trim
you could also use the stock fill location and pipe to the tank
assuming you could mount the tank on the drivers side
if you look inside that panel it does have a hump around the filler neck inside the bed
Old 12-23-2015, 01:13 PM   #17
OrrieG
OrrieG's Avatar
Probably but look where the fill door is, right in the middle of where a FS bed spear is. I also considered putting the fill in the top of the bed rail or on the side above the spear, dropping down and across to the tank.
Old 12-23-2015, 01:30 PM   #18
OrrieG
OrrieG's Avatar
Originally Posted by Dan in Pasadena View Post
Frank,
I added an elbow to my fill pipe for the vent and kept the stock vented cap. You could run the hose up the stake pocket and use a roll over vent on the end (roundy car and off road guys use them). If you use fuel rated hose (not cheap in 1.5-2" size) it will not deteriorate. I found that the some consumer auto part stores sell glorified radiator hose as fuel hose so you need to go back and check the container and markings on the hose. I got mine from a local industrial hose supplier, was $16 per foot. They also had some nice clamps that are much stronger than the geared kind.
Old 12-23-2015, 09:44 PM   #19
57chevyman
57chevyman's Avatar
Frank,
that is the standard elbow that came with the kit. it also came with a straight up one, for a thru the bed floor setup. I did not use that rubber hose that came with it, I used fuel hose.
I will take a look at how the vent hose is terminated tomorrow ( my mechanic installed the tank for me )
Frank
1957 Chevy 3100
Old 12-24-2015, 02:07 AM   #20
Dan in Pasadena
Thanks, Frank!
