Old 12-27-2015, 06:55 PM   #101
six8burban
Re: What did you do to your Suburban Today?
Jumping in on this thing again
six8burban is offline   Reply With Quote
Old 12-28-2015, 01:04 AM   #102
LuckyScott
LuckyScott's Avatar
Changed the thermostat, installed new valve covers and gaskets.
Today I also installed a new window regulator in the drivers door.
LuckyScott is offline   Reply With Quote
Old 12-28-2015, 01:21 PM   #103
captpat
I HAVE A 86 GMC 2500 I am trouble having troubles with the brake proportioning valve the right rear break locks up all the time if I could down the road and hold my foot on the brake pedal and warm the breaks up a little bit everything is fine
captpat is offline   Reply With Quote
Old 12-30-2015, 02:01 AM   #104
magicoolbus
magicoolbus's Avatar
Installed my autosound slidebar radio this weekend. I opted for the Bluetooth option. Quite an easy set up to install. Instructions were quite detailed and the radio programming was straightforward. The bluetooth interface worked like a dream, can make and receive hands free calls. Can also stream Pandora and any other audio from my smartypants phones bluetooth. The pita was reinstalling the center AC vent.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 12-30-2015, 10:56 AM   #105
67 Burb
67 Burb's Avatar
JB, are those custom gauges, or did you redo the originals with white face?
Nice radio install, by-the-way.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 12-30-2015, 01:25 PM   #106
magicoolbus
Here are a few more pics of the finished product. Gauges are white vinyl overlays.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
Old 12-30-2015, 06:48 PM   #107
BK72BURB_3/4Ton4x4
BK72BURB_3/4Ton4x4's Avatar
Replaced my 2X4 hatch holder with gas struts
My OE hatch hinges never worked right so I've been using a 2X4 to keep the door from dropping on my head. Finally sourced some gas struts from McMaster: http://www.mcmaster.com/#gas-struts/=10gvykk and now the hatch stays up by itself!
BK72BURB_3/4Ton4x4 is offline   Reply With Quote
Old 12-30-2015, 06:59 PM   #108
4shongo
Re: Replaced my 2X4 hatch holder with gas struts
What part # did you use? Anything else needed for this mod? Simple bolt in with no modification needed? Let me know. Thanks
4shongo is offline   Reply With Quote
Old 12-30-2015, 07:09 PM   #109
BK72BURB_3/4Ton4x4
Mostly plug and play but I did need to tap new threads into the original holes. I'll dig up the receipt and post the McMaster PN when I get home.
Old 12-31-2015, 01:51 PM   #110
BK72BURB_3/4Ton4x4
McMaster-Carr PN 4138T585
Here's the strut I used...specify the 50lb version
Old 01-01-2016, 03:27 PM   #111
56HOTRODDER
not to hijack your thread but has anyone done this to the cargo doors?
56HOTRODDER is offline   Reply With Quote
Old 01-01-2016, 03:59 PM   #112
56HOTRODDER
my bad ,found the thread after all and its a great one
Old 01-03-2016, 05:58 PM   #113
3drburb
Re: McMaster-Carr PN 4138T585
Thanks, I need to do this.
3drburb is offline   Reply With Quote
Old 01-03-2016, 08:59 PM   #114
pwdcougar
pwdcougar's Avatar
Got one more door done! Rough body work and 2 coats of epoxy primer. Two more and the body comes home!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 01-03-2016, 11:25 PM   #115
LockDoc
The Older Generation
LockDoc's Avatar
Yup, I installed them in the '67 Panel Truck and they work great. You will find out quick if your hinges are bad because it will spread the top of your doors apart....
LockDoc
Leon
Old 01-04-2016, 09:27 AM   #116
highwinger
highwinger's Avatar
I spent the last two weeks on my driver side qtr panel replacing the fuel filler and some rust. Here's a couple "before" pics of the old door and rust and a finished pic with the new flush push/twist release cap.
highwinger is offline   Reply With Quote
Old 01-04-2016, 10:53 AM   #117
LockDoc
LockDoc's Avatar
Any more info on the cap. ie: brand, part #, link to web site. The fill on my '67 Panel Truck is on the inside and it has to go. I don't get any gas odor but it's a pain in the butt to have to open the rear doors to fuel it up.
LockDoc
Leon
Old 01-04-2016, 11:04 AM   #118
highwinger
highwinger's Avatar
LockDoc
Biker's Choice: Amazon.com: Bikers Choice Pop Up Gas Caps - Raw... Amazon.com: Bikers Choice Pop Up Gas Caps - Raw...
Old 01-04-2016, 11:32 AM   #119
LockDoc
LockDoc's Avatar
Thanks. I will check it out....
LockDoc
Leon
Old 01-10-2016, 12:24 PM   #120
Dburger
Dburger's Avatar
Caused some body damage to one of them...no big deal, though.
1953 Suburban Carryall 3106, 1993 S10 4x4 ext cab
1958 Suburban Carryall 3116 ex school bus
1959 Apache 36, 1984 C30 3+3 DRW 6.2 4MT
1967 C10 fleetside LWB, 1969 Chevy Suburban C10
1972 GMC Suburban C10
1972 Chevy Suburban C10 clam shell/tailgate
Dburger is offline   Reply With Quote
Old 01-13-2016, 03:11 PM   #121
missionstreettattoo
missionstreettattoo's Avatar
Had door locks installed in the yellow 1972 suburban I have, to keep my new custom Sundown Audio sub system in the back where it belongs!
missionstreettattoo is offline   Reply With Quote
Old 01-16-2016, 12:56 PM   #122
magicoolbus
I replaced my halogen 6 inch Unity spotlight bulb with a Whelen PAR146 LED spotlight bulb from Sirennet. A couple of before and afters. I went from about 1000 lumens to around 2000. The amp draw is significantly less as well.
Name:  2016-01-16 08.55.41.jpg
Before shot illuminating some masking paper on my toolbox.
Name:  2016-01-16 08.56.42.jpg
Another before, the light isn't shining directly at the camera, it washed out the shot too much. Notice the reflection on the hood compared to the last pic, noticeable difference.
Name:  2016-01-16 09.36.36.jpg
After. Spot detail is much more defined. I am certain that at night this more focused beam will broadcast much further with better clarity.
Name:  2016-01-16 09.28.59.jpg
After.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
Old 01-30-2016, 10:35 PM   #123
3drburb
Put it on a quick diet by pulling the heavy tow hitch.
Old 01-31-2016, 10:51 PM   #124
3drburb
Removed the stock pan hard bar and then added the deluxe from CPP.
It is like night and day driving it, I should have done this a long time ago.
Old 01-31-2016, 11:08 PM   #125
Average Joe
Average Joe's Avatar
Forgive my ignorance, but in what way does it drive better? Is it smoother, corner better, or track straiter? Are you running a rear sway bar?
Thanks for any insight- Brian
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
