Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-15-2016, 12:06 PM   #1
T and S
T and S's Avatar
Use caution heating your garage !
Working on the old truck - I cleaned my front brakes off with brake cleaner. Fired up the kerosene heater and went to work. I was working in a tight corner of the garage. For what ever reason the fumes of the heater and the brake cleaner kinda lingered in that corner where I was working. Started feeling bad, I went outside for fresh air and felt better.
The next day I had a hard time getting my breath and my chest hurt, but the day after I felt fine.
Usually the kerosene heater doesn't bother me, but mixed with the brake cleaner fumes it caused problems.
BE CAREFUL OUT THERE !!
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 01-15-2016, 12:14 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Use caution heating your garage !
Glad you're okay.
Mixing chemical fumes can be dangerous.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-15-2016, 01:08 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
I have wood heat in my garage. When I painted my engine in the winter and had the stove on it seemed like the fumes were 3 times worse than normal....simple reason because all doors and windows were locked tight to keep SOME warm heat in. After 4 hours of painting I had taken probably 7+ air breaks as I would get a headache from the fumes. lol So I now save my painting for the summer mornings. haha
Old 01-15-2016, 01:10 PM   #4
mrtoni
Brake cleaner is a killer.
mrtoni is offline   Reply With Quote
Old 01-15-2016, 01:34 PM   #5
siggyfreud
siggyfreud's Avatar
Just remember that they still need oxygen to burn, so in an enclosed space you're also removing oxygen. When you take that away there is less to dilute the other chemicals in the air, so you're getting the other fumes in greater concentration. I used a forced air propane heater for awhile, and kept the garage door cracked. Eventually I got tired of using propane, or having cool air and warm air mixing, so I coughed up the money and did a standalone heat-pump style unit in the garage.
Now I can keep it at a nice 65* year round, unless it gets particularly hot (95*+) and then the coolest I can get it is about 72, which is still comfy.
siggyfreud is offline   Reply With Quote
Old 01-15-2016, 02:14 PM   #6
scuderia
scuderia's Avatar
No kidding right? Been welding for 40 years and just discovered this. Acetone is my only cleaner now....
http://www.brewracingframes.com/safe...sgene-gas.html
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 01-15-2016, 02:43 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Guess I ain't using brake cleaner anymore.
Old 01-15-2016, 03:23 PM   #8
canadian_diesel1964
damn glad your ok ! Also swearing off brake cleaner
canadian_diesel1964 is offline   Reply With Quote
Old 01-15-2016, 04:14 PM   #9
ERASER5
ERASER5's Avatar
It was phosgene gas. The CFCs in the brake cleaner burned through the heater. An old story and a deadly one at that.
Just use "California" brake cleaner. No CFCs. It does not clean as well, but at least you will be alive to scrub harder.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-15-2016, 06:32 PM   #10
wjjeeper
wjjeeper's Avatar
I was going to post this link.
Very dangerous stuff gentlemen.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 01-16-2016, 12:11 PM   #11
T and S
T and S's Avatar
phosgene gas !? great...... won't be doing that again.
Old 01-16-2016, 01:54 PM   #12
tommys72
tommys72's Avatar
Nasty stuff!
Phosgene is the chemical compound with the formula COCl2. This colorless gas gained infamy as a chemical weapon during World War I where it was responsible for about 85% of the 100,000 deaths caused by chemical weapons.
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 01-16-2016, 09:43 PM   #13
T and S
T and S's Avatar
I knew about the dangers of brake cleaner when welding. Now I think I will not use brake cleaner under any circumstances.
Old 01-17-2016, 12:43 AM   #14
Chevy_mud_truck
Chevy_mud_truck's Avatar
Had a buddy spend a week in the hospital over use brake cleaner around a kerosene space heater
Chevy_mud_truck is offline   Reply With Quote
