#126 |
Re: All about heaters.
Have two left over when tried to match core, you need one from a Corvette
57-59 off I remember buy thru Nappa. I have one PSHc. # 91477 also Vista pro # 0399056, pwo 7566365 My ph #828-349-3102. Franklin,NC Call if I can help, Howard Flett |
#127 |
60-66 Nut
Finding the correct core size is not the problem. I can get the '64-'66 heater core no problem, just have to have the one end switched. I went to our last radiator shop in town today to find that they have closed for good. Today was their last day. Now I have to drive 35 miles each way, to the next closest radiator shop.
I was hoping that by now someone would be making the correct heater core with the correct tubes, without having the added expense of having to have one end switched.
#128 | |
http://www.classictruck.com/product/...itioning_Items |
#129 |
Heater box all rebuilt and painted and installed. One point - I think most folks know this but just a reminder. The blower motors get it's electrical ground through the housing, so after painting make sure when assembling to have a good metal to metal contact somewhere all the way through to include the firewall or the blower will not run.
If you don't like this ![]() |
#130 |
thanks to everyone for the help,final result BAD WIRE tucked way up in the dash,works like it should now!
#131 |
I have the deluxe heater box with factory air in my '65 C30. It has the under hood heater box on the right in the picture below. I am trying to R and R the heater core but I cannot remove the top from the heater box. I have removed all the sheet metal screws and the five bolts holding the warm air manifold to the firewall. Do I need to remove the whole assembly and split it open on the workbench? The under-dash situation inside the truck is more complex and cluttered because of the factory air so it would be nice not to have to disassemble all that to get to the mounting studs behind the blower motor.
Advice? Thanks!...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N |
#132 | |
#133 |
1961 crewcab
some good info in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=690735 here is the main part: OK I gave the local auto parts store another try. This time I decided to look under an alternate year. I noticed that there was a heater core for a "fresh air" heater and another option. "Re-circulation" or something like that. Under details of the heater core by Murray P#94691 the dimension of the core matched up and the picture looked the same. So I ordered that one. Well I got the core and installed it. It fit like a glove. no shimming, no bending or anything. Lessons learned include: always verify the guy behind the counter, unless you deal with vendors from this forum. They are pretty damn good at what they do. ask for help and/or research this forum. There is lot of info on here. Now we have two known part numbers for the suburban "fresh air" heater core Murray Part # 94691 (O'reilys) and pro-source Part # 91691
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#134 |
![]() Join Date: Aug 2008
The more expensive aluminum heater core that classic industries sells is way better quality and fit than the copper one sold by some other vendors. I bought both and returned the cheaper one.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#135 |
60-66 Nut
Does anyone know the correct resistance value for the heater fan speed resistor? I'm trying to figure out how to check them to determine whether they are good or bad.
#136 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
What are some aftermarket options?
#137 |
I've been following this thread, and between the early and late heaters, Thrifty, Deluxe and whatever, I'm thoroughly confused.
Not one setup here matches what I have on my 66 C20. I HAD the left hand box here, in my truck, with a leaking heater core. Had spare heater box, like the right hand one with a decent core. Turns out to be about two inches shorter than he LH heater core. So, switched boxes. Everything went well, but I can't figure out where the heater cable connects to. There's absolutely no flaps, doors or valves in either of these heater boxes, and I haven't seen any in a single photo in this thread, other than the external lever on the side of the heater box which is connected to some mystery thing.. Am I crazy, or is something missing here? Thanks for any clarifications... PS - and how do you cut down a plastic blower fan? Seems like you'd just create some kind of bloomin' onion thing when the fan started spinning, since the blades would only be supported on one end... |
#138 |
went through the same confusing mystery,decided the only thing that mystery arm does is control the amount of water flowing through the core thereby adjusting the temp level of the air being blown in.Since i will probably run the heater on max when i do,I've decided to forget about that lever completely.
#139 | |
Pictures? |
#140 |
60-66 Nut
There is no ranco valve (water valve) on the '64-'66 heaters from the factory.
The Thriftair and Deluxe heaters will appear the same in the engine compartment. The Thriftair will have a smaller heater core than the Deluxe heater. The Thriftair heater has a single push/pull/turn knob inside the cab. The Deluxe heater will have 3 levers with knobs inside the cab. As for levers and flaps, the Deluxe heater will have a air flow flap inside the box in the engine compartment. It will be up close to the firewall with the lever arm on the right side towards the inner fender. This lever can be seen in the above pic at the top right. This is where the cable from the 'heat' control on the dash connects.
#141 |
Thanks for the info...now if I could only get these photos off my phone. Looks like I've got one of each, a Thrifty and a Deluxe. But both have zero flappage. Not one flap between 'em. No lever to attach flaps to, the heater cable just flops around under the dash, looking for work.
#142 |
What makes the in cab (cheaper heater) less capable?
#143 |
No defrost ductwork
http://s1299.photobucket.com/user/jb...23904108567829 |
#144 |
#145 |
I have the heater lostMY65 listed above. I modded a new fan and motor from a 96 air cond camaro. the thing will blow you out of the cab on hi lol.
1961 chevy K10 my build is------------61K10 build |
#146 |
Cool. I just picked one up in the forum's parts section. My other concern was how good does it work at defrosting? - beings it's recycling inside air.
#147 | ||
I found a great reply by Mark about the Recirculating Heater:
#148 |
![]() Join Date: Mar 2011
If you want fresh air with the econo heater crack the vent on the passenger side it pulls air from that direction.
I second that it is enough for winter driving as I live in Colorado and have been daily driving mine sense 1982.
63 k20 with cummins 4bt, owned sence 1982 |
#149 |
Does anyone have an idea on this? I just bought the new plastic fan from LMC and it seems to be too big for the box...is shaving it down the answer?
#150 |
I recently purchased three new reproduction cables for my 1964 with Deluxe heater but the fit and quality is very bad.
Can anyone recommend a place to get high quality reproduction cables? I would also consider good working originals. A PM might be more appropriate. Thanks!
GMC |
