'56 GMC 1 ton dually flatbed project.
I thought i would share my new project.
It's a 1956 GMC 1 ton dually flatbed with a Chevy straight 6. It has a whopping 37k miles. On the body, not sure on the engine. |
Re: '56 GMC 1 ton dually flatbed project.
Cool!
What are the plans?
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
That's it. I'm moving to ID. You guys still have a bunch of cool stuff to find.
Well, I'm kind of torn on the plans.
Originally, I wanted to turn it into a 4x4 Dually tow rig. I even picked up this 80k mile, but extremely rusty 1978 Chevy K30 Dually as a parts donor. It even runs really well. The problem is, I'm kinda digging the '56 in its current state. I'm tempted to just get it running, fix the brakes, and drive it as-is. If the straight-6 turns out to be bad, then maybe a 12 valve cummins or LS swap. |
Hmmm, it won't let me post the pictures. Something about a missing security token?
So, for now, I need to get the GMC running and stopping so I can get it out of my work's parking lot.
Any recommendations on where to get the ignition and door lock sets? I also need to figure out why the brake pedal goes straight to the floor and sticks there. |
#8 | |
and a few others
Here's some helpful info on that: http://67-72chevytrucks.com/vboard/s...ad.php?t=58386
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
check the brake pedal and see if you have a return spring hooked up - it might be broken or not there at all or just like some of us (me included ) just a bit worn out
just sayin --- no offense |
![]() Join Date: Feb 2009
So how's that project going
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#12 | |
