Old 02-18-2016, 12:00 AM   #1
ekneen
Tri Power a '77 Chevy 454
I'm currently working on my mutt of a 1969 K10 running a 1977 454. In the carb category, I have the quadrajet it came with that could use a good rebuilding and on the other hand a GM header and holley tri-power carb off of a '69 Corvette 427.
Anyone here have experience running a tri-power on a big block? Thoughts on tri-power vs q-jet? Given the truck is a mutt I could care less about numbers matching, stock, etc.
ekneen is offline   Reply With Quote
Old 02-18-2016, 03:15 AM   #2
andrewmp6
Re: Tri Power a '77 Chevy 454
If its a daily driver i would run one carb sized to the needs of the engine,If its a more a toy i would run 2 4 barrels on a tunnel ram if you got the room.
Old 02-18-2016, 11:40 AM   #3
77 ChevySport
ekneen:Just a word of caution>67-69 3x2 Int. Manifolds came 2 ways. Round Ports(Which I suspect you got) and Rectingular Ports for the High Horse engines which will not work with your heads. I would keep the Quadrajet for drivablity and less leaks. (All Holleys leak in good time)JMHO-Larry
77 ChevySport is offline   Reply With Quote
Old 02-18-2016, 11:47 AM   #4
truckin 79
I read a article a long time ago that tested 4 barrel vs tripower and the 4 barrel out performed the tripower every time. Tripower is the coolest looking set up IMO but for less headache a 4 barrel is the way to go.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 02-18-2016, 01:36 PM   #5
Tom
driving is in my blood
Tom's Avatar
tri-power on a 4wd?
Old 02-18-2016, 10:33 PM   #6
ekneen
Thanks for the word of caution. I should have started there. Port mismatch indeed. Qjet it is!
Old 02-19-2016, 10:19 AM   #7
slotard
I don't know how much a stock smog dog truck engine would take advantage of that much carb either. I'd much rather have a tiny bit less potential but easy to start and tune than a race engine in a truck.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-19-2016, 05:09 PM   #8
1968vetL-71
Junior Member
1968vetL-71's Avatar
If I read that right u only have 1 tri-power carb?
If that's the case, u will not like buying the other 2 and the intake. Better off selling it in eBay to a corvette guy and staying with the 4bl.
A 67-69 L-68 or L-71 tri-power setup when tuned correctly is a thing of beauty. Problem is guys back in the day didn't know how to tune properly and most setups were removed in favor of a simplified 4 barrel.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
454, k10, tri power, tri-power
