Hoping someone has run into this issue and could help me out.
Working on a 1956 Chevy. Purchased a Borgeson Delphi 600 Power Steering box that was advertised as a conversion kit for the '56 (with modification to the steering column). The problem I'm running into is that the shaft from the clutch linkage is hitting the power steering rod. I called Borgeson and they weren't sure if the power steering box or rag joint should be different for a manual clutch set up. Anyone? |
Re: Borgeson Delphi 600 Power Steering with manual transmission?
Pictures may be helpful.
![]() Join Date: Jan 2011
Seeing what and where it is hitting will help. If the rag joint is the problem, swappng it for a U-joint may cure it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Discovered that the Z bar was not sitting level and that the problem may be with the frame bracket. I cut the existing frame bracket off and will see if re-positioning it will help with clearance.
