02-16-2016, 12:36 AM | #1 |
Carpe manana
Do you have a 1972 Fremont built truck?
Asking in an attempt to narrow down the build month of my Fremont C30. The blue door VIN decal is gone (example below) and the date on the valve cover decal is also indecipherable apart from the year. My VIN ends in Z145444.
Any 1972 Fremont VINs with a corresponding known build month would be a big help. Thanks, Pete
02-16-2016, 09:17 AM | #2 |
Re: Do you have a 1972 Fremont built truck?
Approximated February 24-25th 1972
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 02-16-2016 at 09:24 AM. |
02-16-2016, 10:27 AM | #3 |
Pete here's a couple Fremont 72's.
The red one... The C30 RV |
02-16-2016, 12:05 PM | #4 |
(LOL)
'Zat close enough for ya, Deadhead? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-16-2016, 10:24 PM | #5 |
Carpe manana
Thanks guys! The valve cover emissions decal has a faint but definite impression of the letter "M" that remains ahead of "1972". With what Tim has narrowed down, I suspect a March build on the truck.
02-16-2016, 11:15 PM | #6 |
Pete my 72 from Fremont ...168790 is a May build. Tim already nailed it though!
02-17-2016, 09:38 AM | #7 |
Hmm, mine ends in z164xxx but my I believe my seat belts are date coded for August or September of 1972. I will have to take a closer look at the belts.
Mike |
03-01-2016, 02:02 AM | #8 |
There have to be more remaining in the 2Z145xxx range.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-01-2016 at 02:07 AM. |
03-01-2016, 02:48 AM | #9 |
5/72 - 165562
If you snap a pic of your emissions decal I can try some photoshop tricks with it. You can't even see the date on my blue sticker until I enlarged it and adjusted the levels, then I removed all the chaos around the numbers.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
03-01-2016, 03:03 AM | #10 |
I noticed on your spid, says it is a 400, this is a 402,I mentioned it either had a 454 or a 402....
03-01-2016, 11:34 AM | #11 |
Here is some more data to help things along:
My '72 Highlander is a Fremont built truck Build sheet shows 4-19-72 (....April 19th/1972) VIN numbers are: 161544 ...I imagine that the more data we have on this the more it can be more accurately estimated in cases of missing build sheets. All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
03-01-2016, 11:54 AM | #12 |
I built it
mine is Z101463 think its one of the early ones cause the old paper work from po said it was sold like mid-late 71. dont remember exactly what it says but i know it was sold in 71
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
03-01-2016, 04:03 PM | #13 |
That is an early 72MY SPID, probably Aug 71. They started at 2Z100001. Is it posted to a thread as I'd like to see it?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
03-01-2016, 04:10 PM | #14 |
It would be nice to do this for all plants. Its all about the data. I don't mind compiling the known data if everyone is willing to share what we know factually.
03-01-2016, 04:15 PM | #15 | |
03-01-2016, 04:35 PM | #16 |
Not sure if this is helpful, but mine is a 72 Fremont truck.
03-01-2016, 04:46 PM | #17 |
I built it
just went out and looked and its 8/71 on the door. the truck or the spid? ive never taken a pic of the spid but the truck is on here somewhere. edit adding oldish pic but havent changed anything since
03-01-2016, 04:53 PM | #18 |
While a much later build it is helpful, Thanks!
03-01-2016, 04:59 PM | #19 |
Nice picture for sure, but I must confess its the SPID(data plate, build sheet, blue sticker, POP and any old docs) I want to see. Its all about the data for me and trying to make stockers whole like Pete is doing with this thread.
03-01-2016, 05:00 PM | #20 |
so... as far as present-day data goes... anybody know how many Teslas are being put out per day at that plant now?
edit: Just read that they're producing about 1000 cars per week.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- Last edited by dazza; 03-01-2016 at 05:05 PM. |
03-01-2016, 05:09 PM | #21 |
I think they also come with a button in the glove box for printing(printer mounted under dash) the car's build sheet whenever needed!
03-01-2016, 06:26 PM | #22 | |
45 jph was also another popular line rate (720 per day). K
03-01-2016, 06:38 PM | #23 |
crazy. and to think mine took how many years to just take apart and put back together?
03-01-2016, 06:53 PM | #24 |
For what it's worth here's my Fremont build data from the SPID, Build sheet and door label:
1972 Cheyenne short step Fremont plant 2Z1140xx VIN 10-18-71 build date |
03-01-2016, 08:47 PM | #25 |
Here is 135708
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 03-01-2016 at 08:58 PM. |
