Old 03-05-2016, 12:06 PM   #351
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Originally Posted by 64patina View Post
Making your own pillars, that is awesome man, much respect there
Thanks man, respect to you as well for all the rust repair you did on your 62
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 03-05-2016, 10:26 PM   #352
62stepside longbox
Made a run out to picknpull this morning and got a couple different things. One was these Cadillac seat belt buckles for the tailgate latches just like on the Persh trucks website
Old 03-05-2016, 10:26 PM   #353
62stepside longbox
The ones I bought
Old 03-05-2016, 10:30 PM   #354
62stepside longbox
I also Did some more work on the t5 install. I went to picknpull today because I previously bought the wrong slip yoke. Instead of searching online and paying big bucks I just pulled a camaro driveshaft from the yard that was the same 2.5'' diameter as mine and cut off the front end so that when I get it shortened I can get them to put on the front portion from the camaro. Also when I go to buy ujoints I just have to tell them it's an 86 Camaro. I also pulled the license plate bracket from the camaro as well. It's on a hindge and has a spring that locks in the open and closed position. That how I'm going to fill the gas tank.
Old 03-05-2016, 10:32 PM   #355
62stepside longbox
Then when I got back I worked on the portion of the inner rocker that goes between the cab support and the door pillar
Old 03-05-2016, 10:33 PM   #356
62stepside longbox
And here it is sitting in place. Holes still need to be drilled
Old 03-06-2016, 12:08 AM   #357
TJ's Chevy
TJ's Chevy's Avatar
Nice! Looks good.
Old 03-06-2016, 12:47 AM   #358
62stepside longbox
Originally Posted by TJ's Chevy View Post
Nice! Looks good.
Thanks tj
Here's a video showing the flip up licence plate bracket
http://youtu.be/eTNxc0y1bzM
Old 03-06-2016, 09:56 PM   #359
62stepside longbox
Another busy day with great results. I drilled the holes and welded in the panel that covers the cab support and goes under the pillar
Old 03-06-2016, 09:58 PM   #360
62stepside longbox
Then I made a patch for the lower kick panel
Old 03-06-2016, 09:59 PM   #361
62stepside longbox
Then welded it in and drilled the holes
Old 03-06-2016, 10:00 PM   #362
62stepside longbox
02
Old 03-06-2016, 10:02 PM   #363
62stepside longbox
And then I welded and bolted in the lower door pillar section that I made. All the welds still need to be ground down.
Old 03-06-2016, 10:03 PM   #364
sampsmit000
sampsmit000's Avatar
Looks good!����
1964 Chevy Factory K10 Short Bed
Mitchell Sampson
sampsmit000 is offline   Reply With Quote
Old 03-06-2016, 10:04 PM   #365
TJ's Chevy
TJ's Chevy's Avatar
X2! You got some skills bud. lol Build on.
Old 03-06-2016, 10:05 PM   #366
62stepside longbox
And I was finally able to set the truck down on the new tires
Old 03-06-2016, 10:07 PM   #367
TJ's Chevy
TJ's Chevy's Avatar
Ah, that's what it is.....all that perrty weather. Ya'all done givin us yer rain! LOL
Old 03-06-2016, 10:07 PM   #368
62stepside longbox
And if your driveway doesn't look like this at the end you aren't doing it right
Old 03-06-2016, 10:17 PM   #369
62stepside longbox
Originally Posted by sampsmit000 View Post
Looks good!����
Thanks guys
Old 03-06-2016, 10:20 PM   #370
Palf70Step is online now   Reply With Quote
Old 03-06-2016, 10:32 PM   #371
62stepside longbox
Ha Yeah I've been lucky with the weather lately, the past two weeks have been good weather almost every day.
Old 03-06-2016, 11:17 PM   #372
62stepside longbox
Oh and I also hung the door and it looks like I did my measurements correctly as the door fits pretty nicely
Old 03-06-2016, 11:21 PM   #373
62stepside longbox
Here's another pic of the repaired areas. Still need to finish the kick panel and the floors
Old 03-06-2016, 11:28 PM   #374
AJCK87
Beauty! I'm right there with you. Just waiting on some front supports to finish up the passengers side. I think it fits better when you make it your self
AJCK87 is offline   Reply With Quote
Old 03-06-2016, 11:44 PM   #375
62stepside longbox
Thanks man, I know what you mean about them fitting better if you build them Even though it takes more time.
