Old 03-07-2016, 11:09 PM   #1
62stepside longbox
62stepside longbox's Avatar
Sending unit solution
For those of you relocating your tank under the bed and wanting to keep your stock has gauge I have a cheap solution. My tank going under the bed is a 69 Nova tank which has a 90 ohms sending unit, with the factory system in the truck being 30 ohms this would not work. What I have done is taken the sending unit from my new tank and taken off the ''transmitter'' part. I then took the transmitter off the 30 ohm sending unit and bent and cut the float arm to exactly match the 90 ohm float arm. I then tacked the modified 30 ohm transmitter onto the sending unit for the new tank and soldered the electrical connections then took the float from the 90 ohms unit and put it on the 30 ohms unit. I tested with the multimeter and it works. Be careful when welding not to put to much heat on the components or they may not work.
Here is the 30 ohms transmitter shaped the same as the 90 ohms one.
62stepside longbox is offline   Reply With Quote
Old 03-07-2016, 11:10 PM   #2
62stepside longbox
Re: Sending unit solution
01
Old 03-07-2016, 11:11 PM   #3
62stepside longbox
The 30 ohms transmitter with the 90 ohms float on it
Old 03-07-2016, 11:12 PM   #4
62stepside longbox
Here it is all tacked together with the electrical connections soldered
Old 03-07-2016, 11:13 PM   #5
62stepside longbox
And it works!
Old 03-07-2016, 11:15 PM   #6
62stepside longbox
And this is the extra stuff you will be left with
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
Old 03-09-2016, 01:31 AM   #7
slepysal
slepysal's Avatar
very cool nice write up
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-09-2016, 03:37 AM   #8
62stepside longbox
Thanks, this forum is full of so much great info I though I would help others out by sharing this idea to give back to all the people
Old 03-09-2016, 01:10 PM   #9
frankslagoon
Nice. Do you have a pic of that tank sitten in the trk frame?
frankslagoon is offline   Reply With Quote
Old 03-09-2016, 10:34 PM   #10
62stepside longbox
No I don't have a pic as the tank isn't in it right now. But being a 60-62 frame it is wider in the Rear than a 63-72. Even with this exra width it still hangs below the frame 4 or 5 inches so it might be visible if you have a stock bumper but the bumper that I have hangs a bit lower so its not really visible. I'll post a pic when the tank and bumper are on, should be a couple weeks.
Old 03-10-2016, 12:40 AM   #11
slepysal
slepysal's Avatar
If you can snap a couple of pics of how you mounted it ,that would be helpful to us 60-62 guys
Old 03-10-2016, 01:33 PM   #12
luvbowties
luvbowties's Avatar
Smile Re: Sending unit solution
Good write-up esp. with nice pics. Keep on enjoying these challenges & sharing!.
Sam
luvbowties is offline   Reply With Quote
Old 03-10-2016, 03:52 PM   #13
62stepside longbox
Don't have a pic right now but I'll take one soon. I used a piece of angle iron as a crossmember behind the axle so I could hook the front of the tank straps on and I used the spare tire crossmember to mount the back of the straps to. Keep in mind this is on a longbed so theres quite a bit of length in the frame which allows more room. I also did modify the frame rails a little
Sam
Thanks Sam, if I come up with anything else new I'll be sure to share
Old 03-11-2016, 11:30 PM   #14
Joe Pass
Joe Pass's Avatar
Slick.....
Joe Pass is offline   Reply With Quote
Old 03-12-2016, 02:28 AM   #15
62stepside longbox
Originally Posted by Joe Pass View Post
Slick.....
