04-05-2016, 09:08 PM | #976 |
But Found Her 25yrs Later!
Re: Nostalgia - Pics in Time.
It's not a single hole/slot. The center section is painted black.
04-05-2016, 09:39 PM | #977 | |
If this is a factory assembled truck, it's clearly special order unit with all the variance it shows. You gotta like a factory oddball! |
04-06-2016, 06:53 AM | #978 | ||
That's why the tire options are structured as "Xxx", "Yxx" and "Zxx" where: X = front Y = rear Z = spare Quote:
If that is in fact the Oshawa assembly plant then it had been producing vehicles since the early 1900's. The photo could be immediately after model change, or showing the two short repair lines that occur after the end of final/roll test. If that is the case then either the drivers haven't shunted any vehicles over to that side, or they are only working one line due to production volume (after hours or Saturday repairs). They could be smiling because it's "time and a half" for overtime ("double time" for Sundays). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-06-2016 at 07:03 AM. |
04-06-2016, 09:11 AM | #979 | |
If this was Flint there would be all kinds of vehicle bodies, dunnage, support vehicles (forklifts and electric scooters) and junk stacked in the aisleway. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-06-2016, 01:56 PM | #980 |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
04-07-2016, 04:16 PM | #981 | |
Sorry to dig up an ancient post -- big GM T&C fan, and stumbled across this image on Pinterest, of all things. Noticed there was some confusion as to the location -- one attempt to pin it down said Pontiac, but placed it in the loop. My dad worked in Truck & Coach Engineering for over 20 years, so I know this building well. This is the Truck Engineering building off South Boulevard, just east of the intersection with MLK Jr Blvd. That forward building is long gone, but some of the back buildings, located along what's labeled as "Ring Road" on Google Maps, are still standing. GM completely vacated these grounds shortly before or after the bankruptcy proceedings. Outside of the scope of this group, perhaps, but this was one of the last shots I took before vehicles were moved out of the back lot. The rail spur behind that lot, which was still known to CN as "Yellow Cab" as a historical touch, was pulled up shortly afterward. -EM |
04-07-2016, 10:15 PM | #982 |
One for today. Hopefully not a repeat.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
04-11-2016, 06:25 PM | #983 | |
From another thread..
04-12-2016, 09:52 AM | #984 |
Just found this image, hopefully it hasn't already been posted here.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures) SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD |
04-12-2016, 10:45 AM | #985 | ||
We left the Truck Product Center in about 2005 (the crash was in 2008); the motivation was that all General Motors engineering should be consolidated at the GM Tech Center in Warren. It added about an hour every day to my commute. The tragedy (in my mind) was that the Validation Center, at the corner of Woodward and South Blvd (now the "M-1 Concours") was only about 10 years old when it was vacated and demolished. The replacement facility on 12 Mile Rd could not hold a candle to the Validation Center in terms of resources and size. Quote:
K
04-12-2016, 02:59 PM | #986 |
04-16-2016, 01:47 AM | #987 |
Rollin' Old Skool
04-17-2016, 12:29 AM | #988 |
Rollin' Old Skool
A little blurry, but I don't recall having seen this before:
04-17-2016, 09:20 AM | #989 |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
04-17-2016, 09:57 AM | #990 |
That GMC crew cab looks great!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
04-28-2016, 11:52 AM | #991 |
I was looking through vintage Yamaha pics (one of my other many obsessions, lol) when I came across this pic with the wonderful C10 in back ground, complete with camper shell even.
04-28-2016, 12:08 PM | #992 | |
Rollin' Old Skool
A couple more I saw recently:
04-28-2016, 12:29 PM | #993 |
Bumpers that's what there for. I think the truck was pushing a protester out of the way?
http://s1299.photobucket.com/user/jb...23904108567829 |
04-28-2016, 12:30 PM | #994 |
In that last pic it looks like the driver is driving his truck thru a pickit line for some sort of strike.
Looks like the person in front of the truck is getting knocked down. |
04-28-2016, 12:56 PM | #995 |
Great new additions!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-28-2016 at 01:41 PM. |
04-28-2016, 01:24 PM | #996 | |
Rollin' Old Skool
04-28-2016, 01:41 PM | #997 |
Stand in front of a truck and you get tired!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-28-2016, 09:55 PM | #998 |
Some for today...
04-30-2016, 08:14 PM | #999 |
Here is one I had and never saw the GMC in the corner till today.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-30-2016, 08:54 PM | #1000 |
Rollin' Old Skool
