03-30-2016, 07:14 PM | #26 |
Re: 72 Jimmy "Colonel Mustard"
03-31-2016, 09:40 PM | #27 |
Carpe manana
Great build - I'm on board!
04-05-2016, 01:22 PM | #28 |
04-05-2016, 01:36 PM | #29 |
04-05-2016, 02:41 PM | #30 |
Dang ,he works fast ,is he in the old Day's building ?
04-05-2016, 06:05 PM | #31 |
04-08-2016, 03:22 PM | #32 |
04-08-2016, 04:02 PM | #33 |
04-08-2016, 04:05 PM | #34 |
05-02-2016, 10:08 AM | #35 |
05-02-2016, 10:26 AM | #36 |
To mate the NP205 to the 4L80E, I bought a kit from advance adapters.
** ** One of the steps is to cut down the tailshaft *** ** ** Then I prepped the trans for paint. I used an aerosol from POR. It really laid down well. ** ** ** ** ** Last edited by ochre 72; 05-02-2016 at 11:03 AM. |
05-02-2016, 11:13 AM | #37 |
Great progress, everything is looking very sharp. You are doing almost the exact same build as me just 100x faster! Curious, was it just easier to find a 2wd donor than a 4x and thats why you went with the c2500? Is all thats involved with converting it cutting the tail shaft just like the older transmissions? Also where did you order the gas pedal adapter plate?
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
05-02-2016, 11:32 AM | #38 | |
** ** I will also be enlarging a hole in the transfer case to accept the adapter. I'm taking it to my brother's machine shop today to have that done. The gas pedal adapter came from a member on this forum (Hart rod). He sells them in the vendor section or the LSx parts forum. |
05-02-2016, 01:03 PM | #39 |
Awesome thank you, i guess it is a little more in-depth process than i thought. Well right on, excited to see the rest of this build!
05-02-2016, 03:53 PM | #40 |
05-02-2016, 04:10 PM | #41 |
Some progress on the rust repair being done.
** Epoxy on the firewall ** ** Test fit ** ** test fit the top ** ** First mock up with old fenders ** ** Firewall had to be "adjusted" slightly. ** ** Final weld in of the front floor. Tunnel will be cut last. ** ** Mock up with new fenders ** ** ** Beefed up the rocker area to stiffen a little. ** ** ** |
05-02-2016, 09:13 PM | #42 |
Wow,looking good .
05-04-2016, 02:31 PM | #43 |
05-04-2016, 07:29 PM | #44 |
Looking good..Hope i win the Power Ball tonight so i can start a frame off resto
05-05-2016, 05:20 PM | #45 |
When I get recovered enough from back surgery I will come check you out .
05-05-2016, 10:36 PM | #46 |
I have read a lot of different builds but it's amazing that no matter how many you read you always see something different in each one. Great job and I look forward to watching the progress.
BR549 |
05-07-2016, 09:13 AM | #47 | ||
Thanks. I enjoy reading all of the builds, learning and picking out things that I want to incorporate into my build. |
05-20-2016, 04:11 PM | #48 |
05-20-2016, 04:23 PM | #49 |
Do you have someone close do your powder coating ? There is a good guy out near me in my community that does great work ? You dont know anyone in need of Blazer side windows and hatch window ,all with gaskets do you ?I have some that need a new home cheap as long as I dont have to ship them. Im going to come down and meet you soon ,Im back to driving now.
05-20-2016, 05:22 PM | #50 |
I'm trying....
Top work. Enjoying the follow.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
