#26 |
Proud Americano
![]() Join Date: May 2008
Re: Manual Air Ride Valves!
hey Dloe
wanting to get a couple of these.I'm local to you. can I get these from you or would you want to ship. please let me know. thanks
Tattooed Cuban Trailer Trash. putting the cart before the horse since 1964. |
#27 |
hi dloe I bought your valves a while back they work great so I need 2 more sets please contact me back thanks.
#28 |
Hi DlOE,
Your valves look exactly like what I need. I want to order 4 of them with fittings. I sent an email to the address on your website but didn't hear back yet. How do I place an order? Thanks! |
#29 |
I plan on running these valves w/ a porterbuilt stage 1 front and stage 2 rear kit. However, in terms of compressor, tank, what size line, fittings, etc I do not exactly know everything I need. If somebody could list ALL the parts needed, even the individual fittings I would really really appreciate. Thank You!
#30 |
Any way you could pair these with a couple gauges and sell me a complete set of 4 valves and two gauges plumbed together?
Thanks |
#31 |
Are these still available?
#32 |
How much would it be for complete switch panel exactly like this all together ready to hook up lines?
#33 |
#34 |
Does it matter which hole on the side you use for inlet outlet as along as they all mount the same?
#35 |
Doesn't matter, long as they are all routed the same.
#36 |
#37 |
hey dloe65. i am planning my air ride out and if i go manual i want to use your valves. probably get it all from you, valves, gauge mount, fittings and so on.
i have a couple questions. i see you have a screw in muffler. can an air line be ut in there and the exhaust ran outside the cab? also, do you have a fitting to run one supply per pair of switches so i dont need to run 4 supplies in and 4 out to the bags? last, can you get me a quote for everything i need plus shipping to 28027? we can discuss in PM if you would prefer. |
#38 |
how easy is it to operate so you get a smooth motion from both sides of the front/rear at once? I like how you have these mounted but not never having operated air ride before, not sure is what I am wanting is possible. basically i dont want to have to lower/raise each corner individually if i can avoid it. so if these valves are as smooth as i am thinking they will be, operating 2 valves at once should be pretty smooth.
#39 |
Does Dloe make these? can these be purchased anywhere else? not trying to build/sell my own. just out of curiosity
