07-19-2015, 12:08 AM | #801 | |
60-66 Nut
Re: 60-66 Chevy And GMC 4X4's Gone Wild
There are at least 2 different radius arm frame brackets. One is a bit lower than the other. I would use the lowest one, or maybe fabricate your own. There are 'C' bushings available with different degrees of rotation in them.
07-19-2015, 08:25 PM | #802 |
I know that's been done I remember a few yrs back I think it was a 4 wheeler magazine that there was a 67-72 chevy 2WD that was converted to 4x4 using the FORD setup up front and used the 2WD rear and moved the rear trailing arms to sit I think on top of the rear end... the truck looked really good....
1964 BBC 402 4x4 |
07-19-2015, 08:53 PM | #803 | |
Posted via Mobile Device |
08-09-2015, 02:27 PM | #804 |
But Found Her 25yrs Later!
08-10-2015, 09:14 PM | #805 |
Very cool, might get lost if it's to close to the bush, seems like quality paint work w more than a few hours spent on it too.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
08-10-2015, 09:34 PM | #806 |
my guess would be a wrap rather than a paint job.
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue. http://67-72chevytrucks.com/vboard/s...d.php?t=523009 |
08-10-2015, 11:06 PM | #807 |
Good thinking on the wrap, how easy it is to forget new things..
08-14-2015, 12:42 PM | #808 |
My 64 shop truck on 2002 z71 Tahoe chassis
08-14-2015, 03:23 PM | #809 |
Nice 64 with new underpinnings, can't even tell from far.
11-07-2015, 11:24 PM | #810 |
12-02-2015, 05:28 PM | #811 |
nice truck! i have a flatbed myself, howd you lift her up that high?
1962 GMC 2500 3/4 ton longbed stepside (currently w/flatbed), 4 on the floor, 305-V6-5.0L |
02-21-2016, 01:09 PM | #812 |
1966 Crew Cab & 4X4 Fanatic
02-23-2016, 02:53 AM | #813 |
Well, you did ask for wild.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
02-23-2016, 10:05 PM | #814 |
well, gotta say its...............................................unique
02-23-2016, 10:35 PM | #815 |
66gilbert did the back doors open on that. ..I don't see any door handles on the back
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
02-23-2016, 11:18 PM | #816 |
subscribed
1964 Chevy Factory K10 Short Bed Mitchell Sampson |
02-23-2016, 11:28 PM | #817 |
Slow Build,
I think there's a difference between Wild and Barbaric. No, it is a 2 door Crew Cab. Wish I some more photos and info on this one. Last edited by 66Gilbert; 02-23-2016 at 11:49 PM. |
02-23-2016, 11:44 PM | #818 |
02-24-2016, 09:18 AM | #819 |
Hey have any of you guys had trouble with stock lug studs being too short for some of these new aluminum rims , I'm looking for some longer 7/16 565 shoulder like 4x4 have on the front but not having much luck , soon be ready to drive though so I'm searching.
02-24-2016, 09:42 AM | #820 |
Check out the Dorman Catalog. They have a ton of different size studs.
- Patrick 1964 GMC pickup lwb ~ My newest build! 1937 Ford Coupe ~ Custom frame, LS1, quickchange 1950 Chevrolet 3100 ~ Bagged (Sold) 1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car) 1967 Chevelle ~ 454 Triple Black (Sold) 1964 Chevrolet Impala SS (Sold) |
02-24-2016, 11:39 AM | #821 |
1991 K5 Blazer 4x4 "9 ball" 2019 Chevy Silverado Trail Boss 4x4 2018 Chevy Colorado 2 door ZR2 4x4 1988 23' Mako Marine 2005 Harley Davidson Road King |
02-24-2016, 09:45 PM | #822 |
Man that Yellow one that's a whole lot of yeller...I really dig the silver step side and I like the custom touch of those cross flags on the fender...
1964 BBC 402 4x4 |
04-24-2016, 01:45 PM | #823 |
04-24-2016, 08:55 PM | #824 |
Maybe too obvious but a couple of differences I'm aware of are with the grill letters and hubcaps. The 64-65 grill letters (G and C) were oval shaped while in 66, the G and the C were more squared off... plus the 66 had a groove running though the letters which was painted red. The hubcaps for a 66 had a raised ridge around the center and also at the edge of the three pointed star shape (or whatever you call it). The 64-65 hubcaps were flat here.
04-25-2016, 08:44 AM | #825 | |
No big changes just a bunch of little things.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
