Old 04-25-2016, 09:48 AM   #1
tsmith8
Planning ahead.
I am just about to have my '58 Apache on the road for the first time. I purchased it last September and now that spring is here it is just about ready. I want t plan ahead for a project for next winter.
I am 33, so i want to enjoy the truck now and will most probably do a full restoration in later years. That being said i will most likely keep a stock "like" suspension for now and maybe do a full brand new rolling chassis later in life.
What i would like to do next winter is lower the truck down 3-5", install a power steering setup with a tilt column.
What would be my best option to achieve this??
Rear i would imagine should be an axel flip.
Front would be a dropped axel.
Both with new set of leafs.
Can i install a power steering setup with a dropped axel? if so suggestions?
Thanks for everyones input. This site is great to get info from people who have already been there and done that.
tsmith8 is offline   Reply With Quote
Old 04-25-2016, 02:29 PM   #2
Jemezcrusher
Re: Planning ahead.
For the cost of the drop and new springs all round, you may want to consider doing a MII front and what ever in the back. You may be happy enough with that set up to avoid a 15K (today's money) chassis replacement down the road.
Jemezcrusher is offline   Reply With Quote
Old 04-25-2016, 04:29 PM   #3
Foot Stomper
Foot Stomper's Avatar
Re: Planning ahead.
Check this guy out!!!
No cutting of frame..just bolt in for up to a 7" front drop.
http://www.kijiji.ca/v-other-auto-pa...ationFlag=true
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 04-26-2016, 01:54 AM   #4
mdpaulson1
mdpaulson1's Avatar
Re: Planning ahead.
I went mustang ll and a ccp rear leaf kit. I had to change over to a new master cylinder and new brake lines, redo my steering. I'm happy with the results. If you want a staight axel check out Nostalgia Sid's dropped axels http://www.droppedaxles.com/
price is right for parts.
My rear leaf kit came from
http://www.classicperform.com/Store/...ks/5559RLK.htm
I got it on sale and rides much nicer then stock
mdpaulson1 is offline   Reply With Quote
