Old 04-29-2016, 12:18 PM   #51
Jeff's bowtie's
Re: Just picked up this 68 C/30
Just picked up the new bed for the 68 and some 19.5s getting ready to start converting it to 4X4 in the next couple of days
Jeff's bowtie's is offline   Reply With Quote
Old 04-29-2016, 12:23 PM   #52
R.S.S.
R.S.S.'s Avatar
Nice Deck!
R.S.S. is offline   Reply With Quote
Old 04-29-2016, 08:11 PM   #53
57taskforce
All about them K’s
57taskforce's Avatar
That's gonna be a really nice piece of iron Jeff. I'll have to come see it this summer when we come home.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 05-01-2016, 06:42 PM   #54
Jeff's bowtie's
Set the bed on today to see how it looks on the truck
Old 05-01-2016, 08:50 PM   #55
flashed
Bed looks good ,who made it ,how much overhang over the wheels ?
flashed is offline   Reply With Quote
Old 05-01-2016, 09:04 PM   #56
Jeff's bowtie's
Bed made by Aluma and the bed is 96" wide with 8" over hanging the outside tires but the ho72 is being replaced with a Dana 70 dually rear from a 91 crew cab dually putting the tires right out to the edge of the bed
Old 05-01-2016, 10:29 PM   #57
flashed
What is the benefit to adding the later model rear end other than being wider ? I may need to do that to my 72 1 ton as the bed is too wide .
Old 05-02-2016, 07:26 AM   #58
Jeff's bowtie's
Gives updated rear with 3:73 gears and if your hauling it gives more side to side stability but I'm converting it to 4X4 so I just like the wheels out to the edge just looks better that's my opinion
Old 05-02-2016, 10:03 AM   #59
35boulder
35boulder's Avatar
I guess you are planning on working this truck! Gonna be a nice one.
35boulder is offline   Reply With Quote
Old 05-02-2016, 09:15 PM   #60
Jeff's bowtie's
Old 05-08-2016, 10:23 PM   #61
Jeff's bowtie's
Well I'm starting to convert the C/30 to 4X4 got a lot done today should have the front done in the next day or two I'll keep updating pics
Old 05-09-2016, 10:05 AM   #62
flashed
Im still hanging around watching .
Old 05-09-2016, 10:18 AM   #63
old Chevy guy
old Chevy guy's Avatar
Really interested in the conversion ,have thought about doing this to my truck for years. What are you going to use for a front axle? Are you using all 67-72 components or will this be a custom upgrade using newer parts? Yes please keep posting lots of pictures!
old Chevy guy is offline   Reply With Quote
Old 05-09-2016, 10:22 AM   #64
tkeduk8r
tkeduk8r's Avatar
SUB----SCRIBED! Been wanting to do this to my 68 c30 as well.
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 05-09-2016, 06:52 PM   #65
Jeff's bowtie's
I'm using a Dana 60F in the front and a Dana 70HD in the rear both axles are out of a 84 K/30 dually I'm going with a 4inch lift and 19.5 wheels with 225/70/19.5 tires and for the trans & transfer I'm using a SM465 & 205
Old 05-09-2016, 06:59 PM   #66
Jeff's bowtie's
I didn't have a lot of time today to work on it but I did get the 2WD K member removed and the 4X4 engine cross member in I'm leaving the engine in the stock 2WD location as opposed to moving it to the rear like the 4WDs are this way I'll use the front drive shaft out of the 84 and use the original shroud on the radiator
Old 05-09-2016, 07:00 PM   #67
Jeff's bowtie's
Pic of cross member
Old 05-09-2016, 07:36 PM   #68
57taskforce
All about them K’s
Very nice!
Tyler
Old 05-09-2016, 07:45 PM   #69
Jeff's bowtie's
here's a pic of the 19.5 wheels I'm putting on the truck
Old 05-09-2016, 08:22 PM   #70
72 Super
72 Super's Avatar
Those wheels will make it really stand out along with the bed you are using.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 05-09-2016, 08:44 PM   #71
Jeff's bowtie's
Thanks I was going to use the P30 steel wheels but seen these and had to have them
Old 05-10-2016, 12:00 AM   #72
old Chevy guy
So that is the stock 67-72 4x4 crossmember,correct?
Old 05-10-2016, 01:26 AM   #73
Jeff's bowtie's
Yes everything is off a 72 4x4 frame engine mount,front radiator core support mounts and frame mount and shackles for the leaf springs to mount to and the steering box bolts right up to the 2WD frame
Old 05-10-2016, 07:08 AM   #74
Those wheels will look good with the aloomya bed. I would have liked it with the stock steel Budds, but gotta balance out that fresh bed
Old 05-10-2016, 08:12 AM   #75
old Chevy guy
I knew the front suspension was supposed to bolt up in the case of a 10 or 20 but wasn't sure if there was more involved or more of a custom installation on the C 30 frame. So is the 84 k30 axle going to bolt right in without modification too?
