02-21-2016, 12:32 AM | #401 |
Re: S10 Swap how to
check my signature, I have done it twice with a 65 and a 47 and am doing it again with a 49.
02-26-2016, 10:23 AM | #402 |
Re: S10 Swap how to
Cool build!!
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
02-29-2016, 09:13 AM | #403 |
Re: S10 Swap how to
Can you plz go over the radiator section with me. I am like confused why did u buy another core support. I bought the 19 x22 radiator and it seem not to fit by milli meters lol. Thanks for your help.
Big Frz |
02-29-2016, 09:16 AM | #404 | |
Re: S10 Swap how to
Big Frz |
02-29-2016, 11:05 AM | #405 |
Re: S10 Swap how to
BigFrz, I don't think Chris (skymangs) is suggesting you buy two core supports. In the post you refer, #6, he had two projects going and to get a picture sequence, he used the Chevy support as a start and the GMC support to show the complete. Now why your radiator don't fit in your support, I don't have a clue but I feel sure it has nothing to do with you needing a second support. Clay
02-29-2016, 02:53 PM | #406 | |
Re: S10 Swap how to
I've got some pics of how I had to trim mine for a 19x22 radiator in by build, post 75: http://67-72chevytrucks.com/vboard/s...=664837&page=3 |
03-15-2016, 03:31 PM | #407 |
Re: S10 Swap how to
I have a question as to why everyone has trouble getting the steering lined up. My uncle has a 1988 s10 with a sb 350. The steering shaft goes through the headers no heim joint. What is the difference with the 47-54 s10 swap?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
03-15-2016, 03:56 PM | #408 |
Re: S10 Swap how to
the motor moves back on the frame 4-5 inches with the old body. s10 swap mounts move the motor about 3.5-4 inches forward. that is 7.5-9 inches difference
03-15-2016, 05:38 PM | #409 |
Re: S10 Swap how to
It also depends upon which headers you are using, and where exactly the steering column exits the cab. My GMC cab is slightly different from the Chevy cab, and as I recall, some people with Chevys move the column in order to center it between gauges.
http://67-72chevytrucks.com/vboard/s...s10+frame+swap |
03-16-2016, 04:27 PM | #410 |
Re: S10 Swap how to
Thanks guys. Good to know. (and knowing is half the battle)
04-13-2016, 11:34 AM | #411 | |
Posted via Mobile Device |
04-13-2016, 12:15 PM | #412 |
Re: S10 Swap how to
04-13-2016, 12:18 PM | #413 |
05-19-2016, 09:57 AM | #414 |
Re: S10 Swap how to
For the radiator, is it 19 wide or 19 tall?
Thanks for all the help |
05-20-2016, 12:48 AM | #415 |
Re: S10 Swap how to
19" wide and make sure the bottom connection comes straight out, 90 degrees, some come out 22 degrees. Or a least choose connections based on your water pump configuration. Mine also did not come without a drain port. Cheaper is not always better.
05-20-2016, 09:00 AM | #416 | |
Re: S10 Swap how to
Thanks, where did you get yours. I am having trouble finding a 19 wide radiator. |
05-20-2016, 10:43 AM | #417 | |
Re: S10 Swap how to
My radiator came from Summit, P/N SUM-381324. More on it in my build Post 75: http://67-72chevytrucks.com/vboard/s...=664837&page=3 |
05-21-2016, 01:31 AM | #418 |
You are right, I stand corrected. 22" wide X 19" tall. I got my from speedway. I got a cheap one, would have been better to pay more, if running Automatic, get the integrated AT cooler, drain, straight outlet is better.
05-24-2016, 11:46 AM | #419 |
Re: S10 Swap how to
Ok I have a series of questions regarding my brake setup and I am hoping someone can help. I am doing a hydroboost from an astro and I have the stock steering box from the s10. I have a 5.3 Vortec with the PS pump and I think that the PS cooler is from a 5.3 as well. I am having trouble wrapping my head around how it all has to be connected. I have searched the internet and have found many diagrams that show how to hook it all up. The main question is.... how do I know which is high pressure vs. low pressure and the direction of the flow for all of the components? It is my understanding that the low pressure is usually just regular clamped hosing and the high pressure has the fittings, but I still do not know which direction everything flows. Any help you can provide would be greatly appreciated.
05-25-2016, 09:51 AM | #420 |
Re: S10 Swap how to
What is the main reason you want hydro boost?
Just speaking from experience here.(Not telling you what to do) when running hydroboost setup if the hydra boost unit goes bad you loose your (Brakes and steering!) I found this out the hard way while driving.. Now to help with your question...on the pump it will have A tube coming out usually at the bottom (low side) and a spot for a fitting to go into (pressure side) On my daily driver (looking straight at the hydro unit) left side pressure hose goes to pump, right side pressure line goes to box and the middle (low pressure) goes to the pump (tube) Hope this helps. Mark...
05-25-2016, 02:26 PM | #421 |
Re: S10 Swap how to
Thanks Reaper71!! That's exactly the info I needed.
05-31-2016, 04:38 PM | #422 |
Re: S10 Swap how to
I have a question concerning wheel size and back spacing. I know most people run 2 inch spacers up front and swap to a 4X4 rearend as I did on "FRED". On my new build I am really considering going with Detroit steel or Coys new c33 smoothies, if I have figured/measured right I can have 4.5 backspacing on a 9 or 10 inch wide wheel (for a deep outside lip) and not run any spacers or swap out my rearend. Thanks for your help fellers.
06-02-2016, 01:23 AM | #423 | |
Re: S10 Swap how to
I didnt run spacers on my GMC, and dont plan to on the 49. I didnt even switch to a 4x4 rear on either. backspacing is the key, like you said. I used 0 offset fronts (7" wide 4" backspace) and -12 offset rears (8" wide 4" backspace) and they looked just right. if you call mobsteel spend some time talking to them about exactly what you want. and if you have seen an AD with mobsteels tell them, they keep excellent records of who they sold to and for what application. I ordered some for my friend and mentioned the truck with mobsteels he was trying to emulate, they knew the widths and backspacing and even the front and rear axle widths of the truck. then he said the caps wouldnt fit without modfying them and sent a fedex call tag to pick up the caps, modified them, and sent them back with the wheels. I havent had a better experience with a company before that or since.
06-08-2016, 04:54 PM | #424 |
Re: S10 Swap how to
I don't believe Chris is back yet answering questions but does any one know the Part #'s on the Fuel pump, rotary vane - Oreillys - $80 there is 3 different ones they sell thanks
06-09-2016, 11:04 AM | #425 |
Re: S10 Swap how to
Which are the three pumps you're looking at? Internal, external, why not go to the manufacturer and look at the pump curve information and see which one works best for you.
