06-25-2016, 09:09 PM | #1 |
Pulley alignment issue
I know the community is full of much more experienced people than I, and after hours of trial and error i think i need some more guidance. My crankshaft pulley and the water pump pulley won't quite lineup. I have a long water pump and appropriate pulleys and the water pump and the alternator line up perfectly. I used the tool to install the balancer on my crate 350 and the balancer sits about 1/2 of an inch from the timing chain cover. My question i guess is my balancer on all the way? is that the reason my pulleys won't line up? Or is there some glaring issue that I have completely looked over?
06-25-2016, 09:34 PM | #2 |
Re: Pulley alignment issue
Have you tried an original water pump pulley, even if it's just a single groove to see if it lines up?
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
06-25-2016, 09:46 PM | #3 |
Double check that the balancer is all the way on, use the bolt in the middle of the crank and torque it to spec.
If you only need a little there are spacers for the water pump pulley. The have the pilot hole in the middle and the 2 sets of 4 holes for the fan. Usually one of these will bump the WP pulley out to get it to line up with the crank. I think they typically come with the water pump, but you should be able to find them loose at the parts store. |
06-25-2016, 10:02 PM | #4 |
I could shim the water pump but then it wouldn't like up with the alternator.
06-25-2016, 10:26 PM | #5 |
06-25-2016, 10:48 PM | #6 |
I had to shim my PS and my alt to get mine to work. I'd start with water pump shims and go from there
06-25-2016, 11:04 PM | #7 |
Thanks for the guidance, going to try a new balancer first and if that doesn't work i will shim the water pump. Thanks again.
06-26-2016, 06:17 AM | #8 |
I'd bet with OEM pulleys and brackets the problem would go away. Seldom do the chrome parts fit as well as GM did. I'm no chrome hater, just poor aftermarket part hater.
06-26-2016, 08:29 AM | #9 |
Did you heat the balancer and cool the shaft before trying to install it ? Slowly heating the balancer in water until boil and packing the shaft in ice for an hour really helps to ease install , carry it out to the truck in the hot pot ,remove the packed ice bags use some spray lube line up the keyway using heavy gloves and using a short section of 2x4 and a 2 lb hammer drive it home . Works everytime. I doubt there is anything wrong with your balancer ,just close tolerances .I wouldn't try using the bolt to pull it in you'll just turn the engine or strip / snap off the bolt
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 06-26-2016 at 08:35 AM. |
06-26-2016, 08:31 AM | #10 | |
06-26-2016, 08:41 AM | #11 |
Yeah , pull it off and try again looks like it needs to go in further .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-26-2016, 09:06 AM | #12 |
They don't sit flush when fully bottomed out. Judging by where the timing pointer is falling on the harmonic balanced it is fully installed.
06-27-2016, 12:22 PM | #13 |
06-27-2016, 12:43 PM | #14 | |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
06-27-2016, 12:53 PM | #15 |
Good to hear that my balancer is on all the way, I was reading how these aftermarket pulleys might be misaligned if you use different brands for the water pump and crank pulleys. So I ordered a brand matching pulley...maybe this will solve the problem. Thanks for the pictures gives me peace of mind knowing that I have done this correctly.
07-08-2016, 03:03 AM | #16 |
I went through hell with chicom pulley's. The speed shop recommended I bring them back if they did not fit. I wonder what they knew that i did not. when you gotta shim everything to make it fit......something is very wrong. I took anger management classes after that.PTSD
07-08-2016, 07:34 AM | #17 |
I won't use chrome nuttin. I've never had to shim nuttin. I won't use chrome nuttin.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-08-2016, 09:01 AM | #18 |
I fought misaligned pulleys for years on my truck. Before I installed factory style AC (where you have another belt turning the water pump) I would break the bolts holding the alternator on to the block - which of course then stops turning the water pump. So there you sat. My temporary fix was to carry spare bolts and a couple of wrenches everywhere I went.
What I didn't know was that at certain, higher rpms, the out of alignment belts set up a frequency where the alternator bracket looked like a just plucked guitar string - which of course eventually sheared off the bolts. Long story short I asked a local truck parter guy (da-burb) for a set of pulleys from a factory, unmolested truck. With air as I was planning on that already. That set aligned perfectly. I haven't touched them since. My recommendation is throw the aftermarket crapola away, get a factory set, paint 'em to match what the general did. And don't look back.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-08-2016, 10:10 AM | #19 |
There is a lot of give info on this site and they were real helpful on the phone: http://www.alangrovecomponents.com/Catalog.htm
They have a lot of custom applications available and nice OEM spec pulleys too. I needed a new OEM style PS pump pulley but didn't want to spend the time to find one and get it powder coated, their OEM style fit perfect and solved my alignment problem.
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
Tags |
crankshaft pulley, harmonic balancer, help me please, pulley alignment |
