07-26-2016, 11:53 PM | #1 |
Re: Newbie thinking about diving into a '65 GMC 1000
Yes that's a V8 upper bracket the tanks are wider...At some point in the trucks life someone has put a V8 rad in there as you can see with the lower brackets (also wider than L6) you can NOT put the L6 rad in the correct place with the higher and slightly forward (lower) brackets in there
07-27-2016, 12:48 AM | #2 | |
My top bracket is differently shaped than what 65 GMC showed in his pic, as well. |
07-28-2016, 12:35 AM | #3 | |
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-28-2016, 12:57 AM | #4 | |
07-28-2016, 01:24 AM | #5 |
On a 65 if it had a v6 the emblem would be on the hood not the fender. Let's see a picture of the vin tag, gmc's could be special ordered with an inline six from 64 and up. If the vin on the tag has an "I" at the very beginning then it is an original straight six truck
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
07-28-2016, 01:53 AM | #6 | |
07-28-2016, 02:01 AM | #7 |
So I was trying to adjust the Rochester model b carb this evening prior to setting the timing, but my service manual stumped me. It's instructions were to:
1. Disconnect spark advance at distributor and plug opening of tube. 2. Connect tachometer at coil. 3. Connect vacuum gauge to manifold. 4. With engine running (choke wide open) adjust idle speed screw to bring idle speed to 450-500 rpm (Pow-R-Flo in drive, manual transmission in neutral). 5. Adjust idle mixture screw to obtain highest steady vacuum at idle speed. I couldn't figure out where to connect a vacuum gauge. I assume this is NOT talking about the vacuum advance line from the carb to the distributor, because at idle that should not be pulling a vacuum. Can anyone point me to exactly where I hook up the vacuum gauge? |
08-15-2016, 11:12 AM | #8 |
Registered Loser
Good to see another GMC getting brought back to life.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
07-28-2016, 10:23 AM | #9 |
I= Contains 6 cylinder engine(230,250,292).
10= model 1000 01= 115 inch wheelbase Z= Manufactured at the Fremont, CA plant. 3910= was number 3910 to roll out of the plant. A= GVW of Up to 6000 pounds. So it is a 6 cylinder truck. Looks like someone may have special ordered a larger radiator or something else.
