05-09-2016, 06:14 AM | #101 |
Re: GMC and Chevrolet VIN and Model Number Decoders with pics.
Hi ChevyCheyenne71,
On your model number, the 14 is the code for Axel to Cab dimension. I equated that to wheelbase because wheelbase length provides more useful information than a Axel to Cab dimension does. Also to save space and still include all most all of the trucks found on this website, the trucks over 1 ton, or over 133" WB were left off. The decoders only cover light duty trucks, 133" WB or less. In your case the 14 is a Axel to Cab dimension of 84" to 89". Which equates to a wheelbase of 157" Hope that helps and welcome to the forum. Looking forward to seeing more of your truck. Nice looking Dually you have there.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 05-09-2016 at 06:30 AM. |
05-09-2016, 04:40 PM | #102 |
Thank you guys for your answer i understand now
08-02-2016, 05:51 PM | #103 |
This is by far the easiest vin decoder to use and best looking one i have ran into in my many vin decoder searches. I have a small problem though. The truck i. Trying to decode is a GMC 5500 (Same as a chevy C50) and its vin is different than what are pictured. Its vin is CE50V-A102079
08-02-2016, 07:05 PM | #104 |
My GMC reference materials are packed up right now. (I'm in the middle of a move). But let me see if I can get this off the top of my head.
CE50V-A102079 C = 2wd E = V-8 5 = 2 Ton 0V = Cab & Chassis - = Space reserved for special designation A = Atlanta assembly plant 1 = 1971 02097 = Unique serial number Thanks for the complement on the decoders.
CHEVY/GMC VIN DECODERS |
08-02-2016, 08:25 PM | #105 |
So one of my trucks is also a GMC 1 ton with the 157'' wheelbase (used to be a class B MH) Pretty sure the wheelbase code is 64, that is what is says on the glove box anyways as the model-- CE364OV -- vin: CE3OV ZA 2....
08-02-2016, 08:36 PM | #106 |
my vin doesn't really match up ... {I have CE149S894367------supposed to be original title to factory swb chev 1969 fleetside ......
08-03-2016, 12:15 AM | #107 | |
Model number CE364OV C = 2wd E = V-8 3 = 1 Ton 64 = 157" Wheelbase OV = Cab & Chassis VIN CE3OVZA2.... C = 2wd E = V-8 3 = 1 Ton OV = Cab & Chassis Z = Fremont assembly A = 1969 2.... = Unique Serial number, Starts at 10001
08-03-2016, 12:16 AM | #108 | |
C = 2wd E = V-8 1 = 1/2 Ton 4 = pickup 9 = 1969 S = St. Louis assembly plant 894367 = Unique serial number, starts at 800001. (All Chevy light duty trucks started with 800001 in 1969) This decoder will work for yours. I left off the starting number for 1969 (800001) and 1971 (600001) on this decoder. All other years 67, 68, 70, and 72 started with 100001. (Chevrolet light duty only)
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 08-03-2016 at 12:34 AM. |
08-03-2016, 12:47 AM | #109 | |
What I was trying to pass on is that the 157'' wheel base has the 64 designation not mentioned in your data, unless I missed it in the past 5 pages |
08-03-2016, 07:25 AM | #110 |
Quote from post #1
"We intentionally tailored the decoders to fit the trucks most commonly found on this website" You didn't miss it. We intentionally left it off as well as many other codes that could be found on Chevy or GMC trucks, but are not common on this website. If we included them all the font would be to small or the decoder would be to large to be a quick and easy resource for the trucks most commonly found on this website.
08-04-2016, 10:09 AM | #111 |
Hi Bruceman1968!
This is a GREAT decoder! We just picked up a 1970 GMC K20 for my son's project and I see in the VIN decoder that apparently this truck was a Cab/Chassis. I was wondering if you could help with the "F" designation so I can determine what it was originally. the frame number and the pillar tag match. The truck has been repainted, but it has a Chevrolet tailgate on a GMC, and now that I see this, there is a distinct possibility that it was used as something else before we got it. We do know that it was used to tow heavy construction equipment for most of its life. KE203-FZ64735 MODEL KE25903 3/4T 4X4 350 V8 4 SPEED HD F/R SPRINGS RADIO AMMETER, OIL GAUGE A/C PS (NO PB) 7.50-16.5 WHEELS (SPLIT RIMS) HD BATTERY MED BLUE L/R OUTSIDE MIRRORS TINTED GLASS BLUE VINYL TRIM LOCKING FRONT HUBS I'm mostly curious about the "F" designation....Flatbed? Thanks!
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
08-04-2016, 11:46 AM | #112 |
Happy to help. Here is the correct VIN decoder for your 1970 GMC. The F is for the Flint assembly plant.
KE203-FZ64735 K = 4wd E = V-8 2= 3/4Ton 03 = Cab & Chassis - = Space reserved for special Designation F = Flint Assembly plant Z = 1970 64735 = unique serial number, starts at 50001 in 1970 And here is the correct model number decoder for your truck. As you can see, the 03 designates it as a cab and chassis. KE25903 K = 4wd E = V-8 2 = 3/4Ton 59 = 127' Wheelbase 03 = Cab & Chassis
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 08-04-2016 at 11:53 AM. |
08-04-2016, 11:56 AM | #113 |
Thanks bruceman1968!
I was hung up on the FZ thinking the Z was for Fremont. I was mentally bypassing the dash, but now I see the Z is for 1970. Is the "Fenderside" a pickup bed? And a Cab and Chassis something that maybe would have been given a flatbed somewhere later after delivery? Because right now, it has a pickup bed on it that APPEARS to have the same under color of paint as the rest of the truck, but since it has a Chevy tailgate..........who knows. It does have the 127" wheelbase. There is evidence of a plow having been attached to the front, so it very well could have been a plow truck with a sand bed on it or a water/oil tank. Thanks again!
08-04-2016, 12:20 PM | #114 |
Fenderside is GMC's name for a stepside bed. Your truck was originally built as a cab & chassis, with no bed on it. It could have had a flat bed added to it at the dealership or anytime after that.
08-07-2016, 09:28 AM | #115 | ||
Your unique serial number is clearly 102079 which would make the A the model year. 1969 in this case. Sorry for any confusion my incorrect decode might of caused in relation to the year of your truck. It is a 1969.
08-07-2016, 11:34 AM | #116 |
No worries, im not too worried about it and 99.9% of any parts are the same. Luckily I havent started anything so no harm no foul
08-20-2016, 11:31 AM | #117 |
subscribed
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
11-23-2016, 02:02 AM | #118 |
Hello all seems to me that my vin numbers can't be matched can someone please HELP!!!!
CE134-S110925 Got it Thank you C- 2wheel drive conv cab E- V-8 gas 1- 1/2 ton 34- wide side S- St Louis 1- 1971 10925- Starts at 10001 (1971) Last edited by aanthonys210; 11-23-2016 at 02:16 AM. |
11-23-2016, 02:18 AM | #119 | |
C Conventional 4x2 E V8 gas engine 1 1/2 ton 34 wideside bed - S St.Louis assembly plant 1 1971 model year 10925 serial/sequence number, started at 10001
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-11-2016, 12:50 PM | #120 |
Thanks bruceman1968! Very cool indeed. I was deciphering my Model number, using http://www.caaarguide.com/sub1/id442.html which had my burban listed as a 3-door wagon with liftgate. The burban has the barn doors (aka cargo doors?), so I was wondering someone had done a swap before getting to me. Your 67-72 K10 decoder ring produced this:
VIN = CKE162F145864 C = Chevy K = 4WD E = V-8 1 = 1/2 ton 6 = Suburban 2 = 1972 F = Built in Flint Michigan 145864 serial number ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Model KE10916 K = 4WD E = V-8 1 = 1/2 ton 09 = 127" Longbed (Wheelbase Length) 16 = Suburban/Cargo doors ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ which seems much more accurate! Thanks again!! |
12-11-2016, 02:32 PM | #121 |
iriereggaeman, Glad the decoders helped you out. You have a very nicely equipped suburban there. Welcome to the forum.
03-05-2017, 12:04 PM | #122 |
I am having trouble decoding my 1967 1/2 ton 4x4 suburban. Can you help? It doesn't seem to follow any of the rules. I only have a 12 digit VIN code, and the DMV tells me it should have 14.
Last edited by Kevin McPherson; 03-05-2017 at 12:14 PM. Reason: Trying to add picture |
03-05-2017, 12:18 PM | #123 |
This is the original options list
03-05-2017, 12:39 PM | #124 |
It follows the rules in the picture bruceman1968 posted at 08-02-2016, 10:16 PM above, post #108
According to your VIN and the decoder, you have a 4wd 8-cylinder 1/2-ton Suburban 1967 Fremont-built with 6 digit serial number. That is 12 characters. DMV is mistaken (first time that has happened, probably :-). Thanks for finding this thread and bringing it back to the top. It is interesting and informative and I'm going to bookmark it. Last edited by dmjlambert; 03-05-2017 at 12:49 PM. |
03-05-2017, 02:03 PM | #125 | |
As was indicated it breaks down as, K Conventional Cab 4x4 E V-8 engine (base 283 in your case) 1 10 Series 1/2 ton 6 Suburban 7 1967 model year Z Fremont California assembly plant 156477 Unit serial number Additional SPID coded information Paint code 451 is Medium Blue Poly (metallic) code 506, applied as a two-tone with a code 526 Ivory roof. Model number KE10916 confirms it to be a 4x4 V-8 1/2 ton Suburban with tailgate.
