Old 09-01-2016, 09:46 AM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Looking for pics of Western Chassis reacr shock relocators installed.
Pic please as the product did not come with installation instructions and I am having some one else do the install who is telling me the new brackets kneed to be ground down to fit properly. I can not get Western Chassis to get me an answer for the last three hours.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-01-2016, 03:06 PM   #2
midnight rambler
midnight rambler's Avatar
Re: Looking for pics of Western Chassis reacr shock relocators installed.
I have some installed on my 74 im just away from the truck now. its pretty straight forward install. they sit inside the current shock mount, bolt on the top each side and 1 bolt thru the back. the rounded part at the bottom is where the bottom of your shock bolts to. I believe you supply that bolt or use your old bolt.
midnight rambler is offline   Reply With Quote
Old 09-01-2016, 03:31 PM   #3
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I am not close to the truck either. I have someone doing the install and they are saying they need to grind the brackets to install them properly. I have been trying to get the info from Western Chassis all day. Western Chassis has terrible customer service. I should have looked at their Facebook page prior to purchase. Thanks for your help.
Old 09-01-2016, 03:35 PM   #4
midnight rambler
mine where a tight fit I just hammered them in.
Old 09-01-2016, 03:47 PM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
[QUOTE=midnight rambler;7701280]mine where a tight fit I just hammered them in.[/QU
Are you talking about having to hammer them in the existing
shock mount? If so that is what he might be talking about needing to grind.
Old 09-01-2016, 03:59 PM   #6
midnight rambler
yes its a tight fit
Old 09-01-2016, 04:02 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
yes its a tight fit
Thanks again. Did you use their front relocator kit?
Old 09-01-2016, 04:06 PM   #8
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Without the truck in front of me it looks like the front relocators will be hard to install with inner fenders on the trucks. I might be wrong.
Old 09-01-2016, 05:09 PM   #9
midnight rambler
I believe you have to notch the inner fenders.. I went with the ones travis sell at pro performance
Old 09-01-2016, 05:18 PM   #10
midnight rambler
heres mine but not my truck
Old 09-01-2016, 05:55 PM   #11
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Thanks for the pic.
I am talking the about rears. Apparently I have shock extenders for which no instructions came with the package. This is the email I got from them.
Shock extenders.
Unfortunately, I didn't have access to your invoice until now.
I see that it's not a relocation kit but an extender. We don't have instructions because those a direct
replacement for the existing shackle...however, perhaps we should.
I am searching for something that will help. and will send it to you asap.
Old 09-01-2016, 06:00 PM   #12
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
The front looks like it is going to require the inner fenders to come out. Just a bad design. I should have done more research.
Old 09-01-2016, 06:02 PM   #13
midnight rambler
how tight are they ? when I installed mine. I had to spread them a little. I just spread them with a adjustable wrench. then I drove them home with the hammer. bolted right up. post some pictures. ill get a picture of my rears tonight.
Old 09-01-2016, 06:03 PM   #14
midnight rambler
the ones I used on fronts are the good easy to install no problems
Old 09-01-2016, 06:04 PM   #15
bbbc10
Diggin The SquareLife
jus spread them apart....the ones I had just went right in....its simple to bolt them on
bbbc10 is offline   Reply With Quote
Old 09-01-2016, 07:50 PM   #16
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
You guys talking about rears
Old 09-01-2016, 07:59 PM   #17
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
This is the shock extenders I am talking about.
Old 09-01-2016, 10:06 PM   #18
Willowrun
Willowrun's Avatar
Not the best pic but this should give you the idea. Side holes in bracket go through original shock mount holes.
Old 09-01-2016, 10:24 PM   #19
midnight rambler
My picture not much better
Old 09-02-2016, 12:00 AM   #20
SkinnyG
SkinnyG's Avatar
I made my own, based on pictures I found. Same idea:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 09-02-2016, 09:38 AM   #21
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Once I got to the shop to lend a hand it was painfully obvious what I could not understand thru text. The top of the bracket does not have the indentions at the top like the ones in my picture above in the previous post. The bracket will need to be ground down on the top to allow full extension. I will also have to re-drill the hole to get it to line up as well. I do not recommend their brackets. They should have been a complete bolt one installation with no mods necessary. I am returning the front extenders as well because you have to drill holes in the top of the frame and that is not accessible without removing the inner fender. There are better designs available. I will post some picturess later but here is a sketch.
Old 09-02-2016, 09:59 AM   #22
ultrahd4me
ultrahd4me's Avatar
You shouldn't have to grind anything off the brackets, but you will have to open the hole size on the top hole of the original mount. Then the new bracket should bolt up with plenty of clearance. I'll get you some pics tonight if needed.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 09-02-2016, 10:10 AM   #23
ultrahd4me
ultrahd4me's Avatar
I had one pic on my computer of the bolt hole you'll need to open up, I think from 7/16 to 1/2". In the pic you also see another problem you may have to address with the bolt hitting the leaf spring plate. About a 1/8" of clearance is needed on a 4 leaf pack and about 1/4" is needed on a 3 leaf pack.
Old 09-02-2016, 11:21 AM   #24
midnight rambler
im not getting it, are you thinking it should mount like your red outline ? if so these mounts will not work like that..
Old 09-02-2016, 11:45 AM   #25
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I see. If we open the bolt hole it will allow the bracket to slide down and it will clear the axel housing. It was already installed when I got there and I didn't think that all the way thru but makes perfect sense.
