#4776 |
Re: Restoring Rusty
It would be wise to get that cylinder head magnafluxed, that buildup on the spark plug is from coolant.
#4777 |
![]() Join Date: Aug 2014
Re: Restoring Rusty
Never heard of buildup from coolant, wouldn't it just evaporate, I think its from oil blow by cause of the bad/stuck/broken oil rings, but we shall see if when I put it back together and drive it for a while, its all part of the learning process
#4778 |
Re: Restoring Rusty
Yea, it didn't seem like coolant to me, I think I mentioned in another thread it might be rings.
As much as you have in exhaust gaskets Gregg, you could have just got some better fitting headers lol |
#4779 |
Re: Restoring Rusty
#4780 |
Re: Restoring Rusty
#4781 |
Re: Restoring Rusty
best part of working on the truck is that it comes with it's own workbench
#4782 |
Re: Restoring Rusty
time to clean these jugs
#4783 |
Re: Restoring Rusty
then it was time to clean the heads
now we aint going for perfect here, just more better |
#4784 |
Re: Restoring Rusty
and the exhaust side, all the gaskets like to stick to stuff
#4785 |
Re: Restoring Rusty
the intake gasket was the worst, it was stuck around the water passages real good, I can't recall if I used any adhesive around these ports or not
#4786 |
Re: Restoring Rusty
and the driver side cylinder head
#4787 |
Re: Restoring Rusty
went with these standard size Sealed Power cast iron piston rings on a recommendation from an old machine shop old timer, he said these seat better than the stainless steel ones or them fancy ones
#4788 |
Re: Restoring Rusty
got a proper tool for the job, an eight dollar ring spreader
#4789 |
Re: Restoring Rusty
'Cause if you liked it then you should have put a ring on it
If you liked it then you shoulda put a ring on it Don't be mad once you see that he want it If you liked it then you shoulda put a ring on it Oh, oh, oh |
#4790 |
Re: Restoring Rusty
Dude, you are prodigious! I can't believe how far you got into that motor in such a short amount of time: Let's see. ..wife's gone, the football game is over, kids don't need to eat til six thirty. ..why don't I pop the top off the motor and have a look-see. Hmmm, still got some time. ..I'll pull the pistons out too.
Dang! |
#4791 | |
Re: Restoring Rusty
#4792 |
Re: Restoring Rusty
well it's 9:00 AM, took today off, so let's see how much we can git done today?
#4793 |
Re: Restoring Rusty
well by lunch time, so three hours later the pistons were in and torqued down to spec, I'll be honest with you I didn't think it would take me this long to drop them in, but hey I'm a One Man Circus Act
so here's how we did it first I do NOT recomment this piece of junk adjustable piston ring compressor, but hey it's what I had I bought it back when I was young and stupid, now Summit got them non adjustable funnel tappered ones which are awesome |
#4794 |
Re: Restoring Rusty
always use protection
#4795 |
Re: Restoring Rusty
we also went with Sealed Power brand con rod bearings but these were from Mexico, I dabbed these in oil to give them some stick-to-it-a-vness
#4796 |
Re: Restoring Rusty
so around 9:30 am we got our first piston in...
#4797 |
Re: Restoring Rusty
... the others went a bit quicker
I did them in numerical order - just because, but making sure I could fully rotate the crank by hand after each one |
#4798 |
Re: Restoring Rusty
the driver side all done
#4799 |
Re: Restoring Rusty
and the passenger side all done
#4800 |
Re: Restoring Rusty
here's what the con rod and cap looked like, normal wear and tear if you were to ask me, for a 42 year old enjin
