How would you clean up this engine bay
Looking for some suggestions on how to clean up my engine bay. Last weekend I pulled out my original 350 that had a catastrophic failure and am in the process of replacing it with another members donor 305 just to get it back on the road until i rebuild or go a different route. I'm limited to time and space right now as the truck is parked in the driveway of my condo so welding / spraying will not be an option this go around.
I'm thinking I will de-grease it, sand it and rattle-can it. Maybe relocate the MSD box (suggestions welcome) and fill any unused firewall holes the grommets. I'd really like to get rid of the ugly heater / ac box as it isn't in use and just replace it with a standard heater box with only 1 inlet / 1 outlet but I will probably leave that until next time. Thanks for your input
1969 GMC K2500 |
![]() Join Date: Jan 2001
Re: How would you clean up this engine bay
The firewall is different on the AC and non-AC cabs, so just replacing the heater box won't work.
A good scrubbing and some paint will do wonders in there. I started out the same way, but then I got ambitious and started pulling the radiator support, inner fenders, brake booster... Three years later I'm still looking at a bare frame from the firewall forward. |
#3 | ||
"I ain't nobody, dork."
Here you can see where I mounted my MSD box. Made the sheet metal mount myself.
Gary
Since you have the engine/trans out. Take your wheel wells out, sand them down and paint them. Then sand and clean your radiator supporting battery tray, and paint it to. You'll be amazed how much this will "clean things up" under the hood.
not to hi-jack this thread but what cruise control box is that?
Not sure if you can do this where the truck is now, but I am thinking pressure washing would be a good start. When I got my 69 home, I pressure washed the entire underside, and then, carefully did under the hood wherever I thought I could without causing damage.
After the pressure washing, a degreaser, then scrubbing. The suggestion of removing and painting the inner fenders and rad support are really good ideas. This is so worth it, as after you do this, it becomes a pleasure to work on the truck.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
![]() Join Date: Feb 2009
Long ago in the same situation, I just used degreaser and a single stage spray gun. No other prep but tape. It was a cold January too. Two decades later the engine bay still looked great, at least it did before the tear down. Rattle cans work. I knew an old guy with a beautiful Cheyenne who rattle canned everything but the exterior body. That said, a spray gun is pretty easy. If you have the option I'd use one.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. "kit" for restoring the (a) truck from ground up. My build thread, and more on the kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
How much money and time do you have?
If not much of either, I'd try and use a degreaser and spray paint the inner fenders, after removing them. If you have time, money, and/or your own gear, disassemble and media blast and then repaint. |
#9 | ||
Not much time and money to spend on it this time. It will be coming back out in a year or two and hopefully I can dig a littler deeper into at that point. Quote:
Thanks for all the input, I'll post pics when I get it back on the road.
1969 GMC K2500 |
My home driveway low buck (lots of elbow grease) method follows: spray down engine compartment with a good "gunk" type cleaner. let it soak but don't let it dry, wire brush greasy areas as you let the "gunk" work. Then make a big tub of laundry detergent in some good hot water and scrub down the whole engine compartment with a big bristle brush. Hose it off, and let it dry. Should end up pretty clean, degreased and ready for some paint. do it twice if its really greasy. good luck
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
don't over think this . if its a show truck or a restoration that's different. clean it sand it some then rattle can it. I think flat black or semi gloss looks the best.
Im a big fan of powdercoating the inner fenders, core support and any other brackets for the core support. Keeps it looking nice, will never rust where you cant see it. Also gives you a chance to clean up the frame rails and firewall better.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Scotchbrite, degreaser, and a ton of work. Then some masking and a couple of cans of underhood black (or SEM Trim Black, my favorite) and it'll look like newish.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
![]() Join Date: May 2012
I bet the firewall will clean up nice. Do one bite at a time. Take a spray bottle of 409 spray cleaner. Spray a 12"x12" area and wipe with a red shop rag. Do bits at a time. I bet some 409 will make that fire wall clean up nice. Clean the wires and everything. Can't tell you how many times I've made wire insulation look like new with 409!
409 is my go to cleaner. But I now use "Tub O Towels" to clean up my hand tools. Easier than spraying 409. From what I see you don't need a heavy degreasing, just some elbow grease.
White K20 |
#15 |
409 is great, Fantastik is good, and even GoJo hand cleaner works well for getting grease and grime off of wiring harnesses.
I've take the whole harness into the laundry sink and soaked it in Tide and then cleaned it to like new, but there's always a risk of water damage/rust/oxidation in the connectors when you do that. I blew it all out with compressed air fairly diligently though and no problems to date.
#16 |
![]() Join Date: Aug 2014
Here is what I did
1. Power washed the engine bay 2. Pulled the engine and whole front clip 3. Re-power washed and degreases the front frame and suspension 4. Powder coated the inner fenders, core support, battery tray and hood hinges 5. Wire wheeled and cleaned up the frame 6. POR-15 the frame and then painted satin black over that 7. Buffed and waxed the firewall and inside the front fenders 8. Re-installed all the parts and pieces
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
#17 | |||
To the OP of the thread looking for cleaner options. Look into the "Degreaser" offered by POR-15. Formerly called "Marine Clean". It is a spray on, let soak, hose off deal. Biodegradable and works like a charm. It's all I use for degreasing anything anymore. Gary
#18 |
![]() Join Date: Oct 2013
Purple power degreaser $5-$10 a gallon at autozone,wear gloves safety glasses, big bristle brush,bucket and a hose. I had to go at the frame and suspension with a scraper before any of that. Shaved off 8 pounds of,oil,grease,mud,rock,sticks,concrete,sand.and that was just from the suspension outside of the frame rails! (Now it's lighter and faster.) Then hit the firewall with some 80 grit to rough it up,then some 120 to smooth it out and rattle canned it with some semi gloss black. Wire brushed and red scotch-brite the frame,same rattle can treatment and color. I'm happy with it for the time being. (Front clip is painted grey for now, saving up for a good paint job.) Custom heater delete plate.😆
I know you can't see the frame, but that's where I really took my time and made it look good because I knew I didn't want to have to do it again later.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
#19 |
local dude uses upholstery cleaner for degreaser/cleaner
He has a 5 gal container of it. Has the hazmat sticker on it too. He puts some in a little 16oz hudson sprayer thing and sprays it on, let sit , hose off Somethin like this https://www.amazon.com/Nanoskin-NA-U.../dp/B016HNYZHW
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
