Old 10-18-2016, 05:21 PM   #26
samkost
samkost's Avatar
Re: How to: Cargo light in a non cargo cab by LFD Inc.
[QUOTE=Longhorn Man;1729137]You mentioned mounting screws... don't forget you need the special rubber encapsulated nuts to prevent from grounding the light body. If you don't take steps to prevent the ground, your cargo light will stay on at 1/2 power or so.
There are two metal spacers I have seen for mounting between the inner and outer cab sheet metal? Is this correct?
Can someone chime in on these two spacers.
I am guessing they offer some stability for mounting?
Thanks,
Sam
samkost is offline   Reply With Quote
Old 10-24-2016, 11:06 PM   #27
kehstr
kehstr's Avatar
Does anyone have a wiring diagram for the dome light?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 08-25-2018, 08:49 AM   #28
Grumpy old man
Grumpy old man's Avatar
I stumbled back on this thread . Here is a look at the cargo light added to a 67, I added 8-8mm red leds for the 3rd brake light function .
Old 08-25-2018, 05:48 PM   #29
Edmond
Edmond's Avatar
Now that looks awesome.
How did you connected it, to the break switch directly?
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
Capelle a/d IJssel,
The Netherlands
Edmond is offline   Reply With Quote
Old 08-25-2018, 07:39 PM   #30
RCbowtie69
RCbowtie69's Avatar
Cool!!!!! love the detail & pictures.It's going to help me with my cargo light.Thanks & keep on truckin''
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 12-16-2018, 07:49 AM   #31
lsversaw
lsversaw's Avatar
Like Samkost, I'm wondering where the 2 metal sleeves go. Do they go
over the rubber nut "shaft", after pushing the rubber nut shafts through the holes from behind the outer sheet metal? Seems logical, but I ended up with metal sleeves with ID smaller than the diameter of the rubber nut shaft. I can drill out the metal sleeves, but first I would like to know if I'm on the right track.
Thanks.
lsversaw is offline   Reply With Quote
Old 12-16-2018, 08:50 AM   #32
Grumpy old man
The rubber compression nuts go in from the outside .just push them in the holes on the truck ,the spacers go over the mounting screws before being inserted into the rubber nuts . they provide support as you tighten the screws the rubber compression nuts expand behind the metal to hold it all in place yet remain isolated . this pic shows the mounting screw without the spacer in place . the spacers hold pressure on the rubber nuts while your screwing them in which helps the rubber compression nuts to expand behind the panel . Without them the rubber compression nuts won't tighten and just pull out of the holes . If you need more pics let me know .
Old 12-16-2018, 09:28 AM   #33
lsversaw
lsversaw's Avatar
Thanks for the quick reply, Grump. You're the best.
Old 12-16-2018, 03:01 PM   #34
LockDoc
The Older Generation
LockDoc's Avatar
The rubber/brass nuts are called "Well nuts" You can get them at the better hardware stores. I got some at my local Ace Hardware.... Fastenal has them too.
LockDoc
Leon
Old 12-06-2020, 10:23 AM   #35
Grumpy old man
Bringing some good threads back up
Old 12-06-2020, 01:28 PM   #36
Killer Bee
Killer Bee's Avatar
thank you Mr. Grumpy, I needed this!
Killer Bee is online now   Reply With Quote
Old 12-06-2020, 04:27 PM   #37
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: How to: Cargo light in a non cargo cab by LFD Inc.
Here is my install thread for 3 brake light install.
http://67-72chevytrucks.com/vboard/s...d.php?t=796782
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
