Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-19-2016, 10:05 AM   #776
7dee2
7dee2's Avatar
Re: 72 K30 Build
That really sux your GVOD didn’t work as planned, not good. I know they can burn up the clutches in a hurry if engaged at low speeds and in reverse due to a lack of lubrication. Also found while talking with GV tech support that they can leak from the tail shaft and that is a sure sign the drive line is too short (I’d assume this condition could create a vibration also?). I’ll second the freekin' expensive part!
We ordered our unit with a fixed yoke and will place a slip in the driveline instead. This is a better idea for us because I don’t know what the exact ride height will be until the truck is completely built. Planning on driving the truck to the vendor for the bed install so waiting to build the driveline isn’t really an option.
Ha, this is what’s happening right now on the K30 build just picked up the new driveline yesterday!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 10-20-2016, 12:50 AM   #777
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 K30 Build
Nice OD unit! I have had some issues with GV units in cummins trucks. But I've had more issues with the US gear OD units when they used to build them. Those were horrid to say it nicely.
Ryan
1969 Chevy milk truck
Old 10-20-2016, 10:26 AM   #778
7dee2
7dee2's Avatar
Re: 72 K30 Build
Originally Posted by 72MARIO View Post
Following along your ac rebuild as well. I used Old Air in my suburban and its headed for the trash can this winter. On the top 3 of worst mods with the gear vendor od being 2nd.
I am planning a factory a/c system replacement
Glad your following, I've been working on the AC a little here and there and will get right back to it after the GV install. Want it ready when the cab gets back from paint.
Originally Posted by notchbackgta View Post
What was your issue with the GV?
From the electronics controls including poor wiring "lazy solenoid " and vibration that I chased for nearly 2 summers I still have a bitter taste in my mouth. Expensive gear vendors only parts.. I thought about it more and having a $3000+ unit behind a $1000 T400 just didn't add up.
I LS swapped the truck and had a well build 4L80E for $2000 and just drive the truck now. If it brakes on a road trip I can get parts are anywhere in north America next day at worst.
72Mario has chimed in before in his dislike for the GV and I can’t say as I blame him due to his experiences. I appreciate his input (http://67-72chevytrucks.com/vboard/s...9&postcount=52) and that of others I’ve talked to while researching this, it’s mechanical so it breaks and knowing what can go wrong is good. Hopefully our experience is better by avoiding some common causes for failure. Time will tell if that was a really expensive hat!
Thanks Ryan, I’ve never owned one of these before but think it’s a pretty cool idea and just had to try one!
This setup is really, really loooong!
Brett
Old 10-20-2016, 02:13 PM   #779
Dieselwrencher
Re: 72 K30 Build
I really think the high torque output of the trucks we had issues with was more to blame than anything else. But, it wasn't my dog to fight. I just had to do what GV would let me do with them. I used to get updates on them from one of their engineers but he must not work there anymore because I haven't gotten any updates for a long time. I think you should be fine with yours. Just try not to lug the engine way down. I think there is the base of the problems. Or guys trying to shift them at WOT.
That looks so nice and shiny.
Ryan
Old 10-24-2016, 09:49 AM   #780
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks for sharing your thoughts and experience with the GV’s Ryan. Got to admit I do like my nice & shiny!
Here’s some pics of the GV fixed yoke option mentioned earlier. With the output tapped this unit will accept a fixed or slip style yoke. New drive line after stripping it, yep forgot to ask the vendor not to paint it, again...
Brett
Old 10-24-2016, 09:10 PM   #781
Dieselwrencher
Re: 72 K30 Build
Brett, your rear shaft is just a little longer than the front shaft on my 72. That looks like a well built shaft.
Ryan
Old 10-25-2016, 10:38 AM   #782
7dee2
7dee2's Avatar
Re: 72 K30 Build
Why thank you Ryan, I’m pretty proud of that shaft!
The T400/205/GV w/yoke combo ended up roughly 56-1/2” loooong. As it sits the driveline measures 51-5/8”, with the rear off the ground and the diff dangling it measured 51-7/8” that’s the max number we gave the driveline shop. So 1350 ends, 3.5” tube and I’m hoping enough travel.
GV recommends Lucas 75w-90 Synthetic so we went with the same for the 205. Spun everything including our fresh 14bolt in drive 4Lo up to about 2K rpm.
A couple days later in drive 4Hi ran it up to I'm guessing 20-25 miles an hour until it finally shifted gears, freaked me out with thoughts of running over everything and smashing into the shelving on the other side of the garage!
Glad to report no crashes, no issues, no leaks, thinking this stuff is good to go for now. Here’s a link to a new video running everything at an idle. https://www.youtube.com/watch?v=M9Vl_w-uQJk
Brett
Old 10-25-2016, 12:19 PM   #783
rgunlock
rgunlock's Avatar
Re: 72 K30 Build
Everything is looking great! Cool video. I'd be tempted to add some steering and mount a chair and take it for a slow ride around the yard
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 10-25-2016, 11:37 PM   #784
First c10
First c10's Avatar
Re: 72 K30 Build
Looking good Brett. I like how you are running it on jack stands. I never really thought about doing that. I think I may try that with the hulk.
Keep it up, that thing will be a beast.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 10-26-2016, 10:37 AM   #785
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thank you, Rick. Very tempting, but no. When I was 14 a buddy of mine and I went cruzin’ around the neighborhood taking turns riding on the fender working the throttle on my first car, a 65 Impala with the hood off. I’d pulled and fixed(?) the carb (busted the linkage doing it) and had to test! Ha, once a fool always a fool you know!
Thanks, Scott. Just don’t let that sucker come off the stands it’ll be a bad day! We'll put it on stands again to bleed and test the brakes under power after the cab goes back on.
Our original evaporator (still needs to be cleaned up) has passed a flush & pressure test at a local radiator shop. The POA arrived back from Benny and looks great. Here are a few comparison pics of the old A6 and the A6 replacement (S6) compressor. On the fence right now about painting it for more of a factory look?
Brett
Old 10-26-2016, 01:46 PM   #786
First c10
First c10's Avatar
Re: 72 K30 Build
Brett the Compressor looks cool. I say paint it and no one will no the difference!!! .
I saved a bottle of R12 so I kept my sons '70 stock just cleaned out the stock 2011 AC compressor and used mineral oil and charged it up with R12. It will freeze you out of the truck....
GO GO!!!
Old 10-27-2016, 10:01 AM   #787
7dee2
7dee2's Avatar
Re: 72 K30 Build
Yeah I believe it, R12 works great.
While researching our AC, I did call around locally most told me they couldn’t get R12. One vendor said they could but it would be $100 a pound, with no guarantee! Even asked a few friends and a buddy of mine has a few cans stashed he won’t part with so, the decision was made to move forward w/134a.
Our plans are as follows everything on the firewall remains factory (2b restored) including a new expansion valve, heater core, gaskets, cloth ducting and various small parts as needed.
The parts list so far:
1 = Modified POA valve calibrated for 134a (Benny) w/low side 134a adaptor fitting (NAPA # 409903?)
1 = Hose Assembly (Old Air # 95-7215A) w/high side 134a fitting built in
1 = Liquid Hose (Old Air # 95-7216)
1 = Harrison A6 replacement (S6) compressor (DiscountACParts # 60-01019NA)
1 = Dual Fan Assembly (Old Air # 50-7230S-2) w/wiring kit, w/jumper harnesses (2=Spal #FR-PT)
1 = Parallel Flow Condenser Kit (Vintage Air # 021567)
Tried several times to get someone at Vintage Air to confirm that a factory style hose kit would bolt to their condenser kit. They would not confirm but we took a chance and it does bolt up. This last piece makes it a bolt in so should be easy peasy!
Brett
Old 10-27-2016, 04:00 PM   #788
Dieselwrencher
Re: 72 K30 Build
Very nice! This winter I need to do the ac on the 72. Hey, did I see an oil puddle under the big block?
Just kidding! It sounds nice and it all looks great!
Ryan
Old 10-31-2016, 10:45 AM   #789
7dee2
7dee2's Avatar
Re: 72 K30 Build
Ha, such a kidder that would not make my day!
Cab update, high build primer/sealer went on next.
Brett
Old 10-31-2016, 11:13 AM   #790
rgunlock
rgunlock's Avatar
Re: 72 K30 Build
Looks nice Brett. I foresee a lot of block sanding in your near future!
Rick
Old 10-31-2016, 11:13 AM   #791
First c10
First c10's Avatar
Re: 72 K30 Build
Looking Good Brett,
Are you going to assemble all the sheet metal before painting? or have you already as I cant remember?
GO GO!!!
Old 11-01-2016, 10:12 AM   #792
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks, Rick the sanding has resumed!
Looking Good Brett,
Thank you, Scott. Yes and no, we did the bare minimum on panel fitment in final mockup (current avatar), back then we got the fenders to match the cab and clear the running gear. Found with the later core support frame mounts we’ve got a lot of adjustment up front. In addition the original born with accident-free sheet metal fits pretty well together, or good enough at least for this new, old 4x4, flatbed work truck!
Wet sand with a little filler. Some rookie got a little crazy sanding the cowl (gouged it with the block a little) and was dismissed for the day, oops.
Brett
Old 11-02-2016, 10:23 AM   #793
7dee2
7dee2's Avatar
Re: 72 K30 Build
More sanding… And the paint is in.
Brett
Old 11-02-2016, 04:27 PM   #794
Dieselwrencher
Re: 72 K30 Build
Looking great! Does that paint can label say purple? It's going to look really nice!
Ryan
Old 11-03-2016, 10:15 AM   #795
7dee2
7dee2's Avatar
Re: 72 K30 Build
Thanks’ Ryan, it is getting really straight and could take a dark color like purple (Big Barney? ) or black.
72 Chevrolet Truck White 521 is a very, very bright white and would be fine except that we do have another white project, our 67 Camaro is to be Ermine White. To simplify, reduce waste and cost I chose to use the same color on both.
Here're some links you guys might find interesting.
http://paintref.com/cgi-bin/paintdetail.cgi?ppg=8259
Scroll down to see this color on a 67 Camaro Pace Car.
http://paintref.com/cgi-bin/colorcod...7WA2261&scomm=
Another round of high build, as well as some more DP90 going on the outer floor and the inner roof that got missed earlier. Some of the original undercoating remains on the outer floor, planning on giving it a fresh coat of rubber undercoating when it gets back to our garage. Right after these pics, we flipped the hood over and installed some new hood pads.
Brett
Old 11-03-2016, 06:29 PM   #796
Dieselwrencher
Re: 72 K30 Build
Are you going to spray anything on it to help with sound deadening while you're at this point?
Ryan
Old 11-07-2016, 10:43 AM   #797
7dee2
7dee2's Avatar
Re: 72 K30 Build
I looked into possibly using LizardSkin, wasn’t aware that their heat and sound deadening material are two completely different products sprayed over the top of one another.
We’ve used jute padding as well as Fatmat in the past. Must say I do like the Fatmat, currently leaning towards their newer black butyl MegaMat with some jute padding again. Might try a mass backed carpet set from stock interiors also. All that stuff and some fresh rubber undercoating should be pretty good I hope.
Mass Back Carpet?
http://www.stockinteriors.com/massba...?RetItem=22494
Brett
Old 11-07-2016, 10:59 AM   #798
notchbackgta
Re: 72 K30 Build
I like the mass backed carpet I put in the Suburban. It helps a lot with the noise
notchbackgta is offline   Reply With Quote
Old 11-07-2016, 05:18 PM   #799
swamp rat
swamp rat's Avatar
Re: 72 K30 Build
I read a Mass Backed Carpet thread here and it sounded promising.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-08-2016, 11:56 AM   #800
7dee2
7dee2's Avatar
Re: 72 K30 Build
Ha, good to hear! I'm thinking that is the plan then!
Removed the radiator and core support to start installing the new fans & AC parts, aux. battery tray, etc. Some of the paint was flaking off the new condenser brackets, a quick scuff & paint fixed that.
Brett
72chevy, dually, flatbed, k30, motorhome
