10-16-2016, 08:38 PM | #176 |
Re: NAPCO Thread
Hey. Looking to do a 4x4 conversion on a 59 gmc. I was thinking about using straight axles from a small body blazer from around 2000. Only reason im posting here is I couldnt find what I was looking for. Is there a better option for axle choice as far as installation and what will I be in for as far as, hanging steering components, adding a transfer case to a muncie 4spd and such. I would like to use a dana 60 front and rear, but they all look to be full size truck axles and I need a 60". Thanks
Posted via Mobile Device |
10-19-2016, 11:49 PM | #177 |
Re: NAPCO Thread
My 57
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
10-20-2016, 12:30 AM | #178 |
Re: NAPCO Thread
c Terris
I would ask what is your plan for the truck?? The Napco stuff is well built but old technology and can be a PIA to find parts for if you start tearing stuff up. If you want to build an ol skool 4x4 and maybe do some light 4x4 stuff then rock on. If you plan to do some serious boggin or trail running, find some late model running gear and run that. You will most likely have to fab some stuff up but there are lots of guys who have done it and it should be easy to find what your looking for. bb
http://67-72chevytrucks.com/vboard/s...d.php?t=385404 |
10-20-2016, 09:20 AM | #179 | |
Re: NAPCO Thread
I like old trucks as they were. No Mudd truck futures for any of my projects
10-24-2016, 01:14 PM | #180 |
Re: NAPCO Thread
A couple 3 Napcos for sale on C/L
http://seattle.craigslist.org/skc/cto/5826120981.html http://seattle.craigslist.org/sno/cto/5797418588.html http://seattle.craigslist.org/see/cto/5841277618.html
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-24-2016, 10:05 PM | #181 |
Hey,
Really just want to drive it on the street with that tall look. Don't want to just throw a lift kit on the 2wd setup. I'de like to go on some moderate trails (no body bashing trails). The problem im having is figuring which axles to use. The 59 is the sam width as a small body blazer which is 60". I would love to use a dana 60 rear and dana 44 front but they are to wide. Is there a simple way to shorten those axles or if I use a axle that is already 60" how do I know the leaf spring will line up on the axle. I've been told if they don't alighn where originally specified the weight of the car could crush the housing of the axle. Obviously people have done this conversion, just need some help. Posted via Mobile Device |
10-24-2016, 10:08 PM | #182 |
Re: NAPCO Thread
From there I will need a transfer case different length drive shaft and rearrange the steering mech. Can anyone reccomend a could transfer case and a good way or place to get the right size drive shaft. If anyone wants to lend some knowledge with that it will be much appreciated.
10-25-2016, 01:15 AM | #183 | |
Re: NAPCO Thread
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
10-25-2016, 10:33 PM | #184 | |
Re: NAPCO Thread
10-25-2016, 11:23 PM | #185 |
Re: NAPCO Thread
c Terris
I might find some new corporate axles and use them rather than the older stuff and fab in the x-fer case you want. Maybe throw in some power steering and better final gear ratio ??? I wouldn't mind having better brakes on my old stuff but the new brake booster helpful in getting her hauled in... ps I still like the old stuff, she is tall....
10-28-2016, 11:37 PM | #186 |
Re: NAPCO Thread
Gorgeous Carryall!
http://eugene.craigslist.org/cto/5848163121.html
10-29-2016, 08:26 AM | #187 |
Re: NAPCO Thread
My entry
72 Cheyenne k/20, Custom Camper 72 Cheyenne k/20 71 blazer K/5 2WD 454, 6 sp. 67 Chevy Napco c30 Dump 56 GMC Napco 4x4 short step 66 Chevy K10 68 Chevy C/30 4x4 |
10-29-2016, 07:10 PM | #188 |
Thanks guys, HO thats exactly what I was looking for. Truck is deffinately getting lifted. Weather or not there will be 4wd put in is still up for discussion. You said the rear bolted in do you happen to know if the axle was 60 "?
10-29-2016, 07:38 PM | #189 |
Re: NAPCO Thread
Two more questions ho455. Did you have to do any frame cutting or body chopping and also did you mean a divorced 205. The 204 didnt come up on the internet. Thanks again.
10-29-2016, 08:15 PM | #190 |
Re: NAPCO Thread
Also if anyone has any ideas for wiring harnesses I have another thread going.
http://67-72chevytrucks.com/vboard/s...=1#post7755549 |
10-29-2016, 11:51 PM | #191 |
Re: NAPCO Thread
Yes you are correct it is a 205. No frames or bodies have been cut, chopped or spindled. The whole goal started out to stay as 1950 as possible. I have used the stock (F-1 1/2 ton) springs and hangers but if I can locate a set of rebuildable F-2 or 3 rear spring hangers I would swap some 3/4 ton springs in the rear. The disks were added after I thought about how often I pull a trailer. Crappy photo of the dana 60 rear as installed.
10-30-2016, 12:35 AM | #192 |
Re: NAPCO Thread
Dhoo! I just realized you asked if it was 60 inches not if it was a Dana 60. From where to where do you want it measured from?
10-30-2016, 10:45 AM | #193 |
Between drum or disc and brake flange to the otherside. So from o.d. Of brake flange. I originally did say dana 60 it just happens I need a 60" axle too
10-30-2016, 09:27 PM | #194 | |
Re: NAPCO Thread
1964 BBC 402 4x4 |
10-30-2016, 10:42 PM | #195 |
Ho455. I didn't even realize you posted that carryall is that your or did you just find it on craigslist.
10-31-2016, 05:26 PM | #196 |
Re: NAPCO Thread
Not mine. If it was it sure wouldn't be up for sale. Passed on a GMC back in 87 before they became valuable and I have been experiencing non-buyers remorse ever since, so now I just look at stuff I can't afford.
10-31-2016, 05:56 PM | #197 | |
10-31-2016, 06:00 PM | #198 |
10-31-2016, 06:19 PM | #199 |
Re: NAPCO Thread
I tried uploading these pictures before, but it didn't seem to work. So I wouldn't be surprised if you see it up here multiple times. The 59 of course sporting primer gray and Rhino line black it has a 350 out of a 70's caprice and a 4spd. Then my 69 Gmc 2500 original paint 396 with a th350 36,000 original miles. Then in the background my dads car( he's the original owner of that one) Different engine now , but originally 396 with a 4 spd, now its something bigger made by Shafiroff Racing.
11-01-2016, 06:39 AM | #200 |
Re: NAPCO Thread
Have you considered Jeep Wagoneer/Cherokee Chief/J10/Commando axles? They are narrower and later stuff is 6-lug
