Old 11-05-2016, 10:43 AM   #1
67cheby
67cheby
67cheby's Avatar
Slosh Tubz now has high transmission humps!
Just wanted to let everyone know about the newest product line from Slosh Tubz we now have High Hump transmission tunnels for 60-66 and 67-72. the 60-66 are $180 shipped and 67-72 are $150 shipped.
We also have stock height widened rear tubs for 60-66 they are $400 shipped
www.sloshtubz.net or call 1-479-599-9664
67cheby is offline   Reply With Quote
Old 11-08-2016, 01:39 PM   #2
creep
Registered Loser
creep's Avatar
Re: Slosh Tubz now has high transmission humps!
NICE! I'm sure those will help some people with their builds.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 11-08-2016, 01:43 PM   #3
67cheby
67cheby
67cheby's Avatar
Thanks man, i sure hope so!
Old 11-08-2016, 07:42 PM   #4
Backpayne
I will be ordering soon!
Backpayne is offline   Reply With Quote
Old 11-08-2016, 07:54 PM   #5
scoot_mcgrute
Looks like fiberglass, are there any weight savings with one of these over factory?
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 11-08-2016, 10:59 PM   #6
Willie 66
Yep, I'll be getting one.
Willie 66 is offline   Reply With Quote
Old 11-10-2016, 07:21 PM   #7
1966FLEETSIDE
1966FLEETSIDE's Avatar
nice so these are 1 pc item verses 2 like stock?if so thata the best idea ever any taxes on these?
1966FLEETSIDE is offline   Reply With Quote
Old 11-21-2016, 03:27 PM   #8
jamesrussell26
in the market for a couple of these
jamesrussell26 is offline   Reply With Quote
Old 11-21-2016, 03:31 PM   #9
67cheby
67cheby
67cheby's Avatar
Thanks!
I honestly dont know the answer to that, i would say they are about the same
LOL!
just call me 1-479-599-9664 or order (www.sloshtubz.net)
Thanks man! no taxes, and price includes shipping
Old 11-27-2016, 02:53 PM   #10
1hihum
I just started fitting mine in last night. I should have it finished tonight or tomorrow. I'll post a couple of pics when I'm done. Minimal trimming so far.
1hihum is offline   Reply With Quote
Old 11-28-2016, 09:51 AM   #11
67cheby
67cheby
67cheby's Avatar
Awesome, thanks man!
Old 12-28-2016, 04:45 AM   #12
1hihum
Sorry for the delay...I got sidetracked by a rear dropmember. Anyways, here are a couple of pics. The tunnel fit really nice with minimal trimming. A little off the top of the hump at the firewall and a little at the back end and it fit right in. You can see a couple of spots where there is a slight gap (at the bend on the passengers side, and right above the gas pedal on the drivers side) but let's be real here...this truck is almost 55 years old. I am totally happy with it and highly recommend it if you need one!
Old 12-28-2016, 08:11 AM   #13
1966FLEETSIDE
1hihum,what type of tool did you use for the trimming?
Old 12-28-2016, 08:42 AM   #14
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Cool addition to available parts.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-28-2016, 10:50 AM   #15
67cheby
67cheby
67cheby's Avatar
awesome, Thanks for the Pictures!
Old 12-28-2016, 10:51 AM   #16
67cheby
67cheby
67cheby's Avatar
a metal cut off wheel on your grinder works nice
Thanks man
Old 12-28-2016, 02:39 PM   #17
1hihum
I just used a grinder with a metal cutting wheel. wear a mask of course! I'm really happy with how well it fits. I used a bead of seam sealer all the way around it ( a little thicker at the bend near the gas pedal and on the other side as well) and it was good to go! I used the old tunnel to reference where to drill the holes and started off small until I knew I had them in the right spots. if it's clear under the truck you can also drill small pilot holes from the bottom (just be careful because you can crack the gel coat on top easily that way)
Old 08-11-2017, 01:26 AM   #18
joe231
joe231's Avatar
Is there any way I can get a 60-66 hump shipped to Alaska? 99645 or 99518
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 08-14-2017, 05:56 PM   #19
drmatera
drmatera's Avatar
perfect. I'm getting ready to cut out my rusty low hump to make room for my 5.3 - 4L60E swap.
1981 K10 (4.8 / 4L60E swap)
1982 C10 (5.3 / 4L80E swap)
1985 C20 Suburban (454 / 4L80E)
drmatera is offline   Reply With Quote
Old 08-14-2017, 07:08 PM   #20
jjzepplin
jjzepplin's Avatar
Any ideas on low humps? I swapped my 4x4 to 2wd and think a low hump would work. I put a metal version on my 4x4 truck that has a 3"body lift. Worked out great for transfer case linkage issues with twin sticks and such.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-14-2017, 07:11 PM   #21
cww180
Which transmissions require a high hump in these trucks?
cww180 is offline   Reply With Quote
Old 08-15-2017, 10:35 AM   #22
LVPhotos
LVPhotos's Avatar
Most. I had to raise center of mine to accommodate T5 which is not much bigger than 3 on tree. Now with Porterbuilt crossmember moving everything up. Its maditory. But you can use small shell and cut as you go. My original v8 was in rear mount. So moving motor fwd might help.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-15-2017, 12:10 PM   #23
drmatera
drmatera's Avatar
Yes, moving the engine forward would most likely cure my clearance issues but I wanted better weight distribution and more room at the radiator so i tucked the 5.3 as far back as I could.
I ordered my high hump yesterday....
